Thread: Ping 1BadZX12R
Created on: 03/11/11 08:51 AM
Ping 1BadZX12R
03/11/11 8:51 AM
When you coming to get all this stuff, I need the space?
2006 ZX-14 parts:
Upper Cowl Passion Red Almost Perfect
RH Center Cowl Passion red
RH Lower Cowls FS Black
LH Lower Cowl FS Black
RH Front Turn Signal Assy
LH Mirror Assy
Rear Seat Cowl Passion Red
Stock Stainless Steel Mufflers R and L
2008 ZX-10R
Complete Exhaust System, Headers, Cats and Muffler
2009 ZX-6R
Muffler Only w/ exhaust valve
2007 CBR 1000RR
Underseat stock Muffler w/ heatshield
2004 VTX-1300C Stock Exhaust w/ Cats
You buy lunch and it's all yours, I'll even help you load it.
RE: Ping 1BadZX12R
03/11/11 5:09 PM
HEY kruz o6 ZX stock l/h & r/h mufflers, is the header pipe with them mate ?
* Last updated by: bean07 on 3/11/2011 @ 5:10 PM *
Badzx14r
Badzx14r's Gravatar
RE: Ping 1BadZX12R
03/11/11 5:15 PM
hey thats my stuff ..but if you need the room you can ship it to these guys .. i'm not coming til April ..
* Last updated by: Badzx14r on 3/11/2011 @ 5:16 PM *
RE: Ping 1BadZX12R
03/11/11 9:43 PM
Negative bean,I have just the stock cans and midpipes.
RE: Ping 1BadZX12R
03/11/11 9:46 PM
Aprils good, were going someplace good for lunch though, no McDonalds.
RE: Ping 1BadZX12R
03/12/11 8:18 AM
No worries kruz I thought so just wanted to get rid of the catylic from the header pipe off my 09 ZX1400
RE: Ping 1BadZX12R
03/12/11 4:02 PM
Bean, I went with a Yoshimura slip-on because the full Yoshi gave only acouple more HP on top with a loss of lowend. The stock '06 headers are very good and best part no cats. You should be able to find a set, lots of 06 owners went with a full system and would like to sell the stockers.
RE: Ping 1BadZX12R
03/12/11 4:21 PM
HI there kruz yeh mate I asked Hub on the hp post a couple of questions regaurding that subject maybe as your such a dedicated bike owner and where talking about that subject if ya don't mind I'LL run it by you cobbar I see in the dyno results everyone else seems to have gained a lot more HP than me so I'm wondering when Goody took my 09ZX to get the PCV installed then dynoed it only increased by 10 hp so as you just implied ya only get a bit more from a full system and privateer says slip-ons do not much else ! so I asked HUB if Gutting the cat out of my header and re-dynoing it would this help ? I've since gone right through the questions posts and found that he already came to the conclusion it dont make any diff as the 08 onwards had a slightly larger headerpips to compensate for the cat restrictions, so all in all why does all the other dyno results make mine look so poor?
* Last updated by: bean07 on 3/12/2011 @ 6:31 PM *
Badzx14r
Badzx14r's Gravatar
RE: Ping 1BadZX12R
03/13/11 2:41 PM
looks like april the 9th a texas raceway kennedale texas ..or crandale on the 30th of april ..
RE: Ping 1BadZX12R
03/14/11 12:48 PM
Have you checked for a dead Kuala Bear blocking the airbox inlet? Don't know Bean mate, looks like you may have been rooked, uhhhh sorry Rook. Seriously though, there are more variations in dynomometers than their are in bikes. You say you picked up 10 HP with just a PC5? I'd say that's pretty good, I don't think I picked that much up with PC3 and pipe, TRE and remap. I'd have one of your mates with a known good running bike run back to back on the same dyno, same day and do a comparison. Better yet, how does the bike run against your mate's on the street or strip? Try synchronized rollons from various speeds in different gears to find out how strong your bike is at different points in the curve and this eliminates the effects of relative skill when doing a drag start. Dynos can lie but the road doesn't. Who mapped your bike after the PC5 update? Mapping makes a huge difference in peak hp and torque figures as well as crisp throttle response. I'd forget gutting the cat, go with a set of Yoshi or other slipons and get them ugly stock chrome bazookas off of there. You'll thank yourself the first time you nail the throttle, the sound alone will give you goosebumps... if not, check your pulse.
* Last updated by: Kruz on 3/14/2011 @ 12:57 PM *
RE: Ping 1BadZX12R
03/14/11 1:01 PM
PM
Allright, just let me know when you're coming by a day or two in advance and I'll have everything ready to go. You outta be able net about 4 or $500 off of e-bay, most of this stuff is brand new or barely used.
RE: Ping 1BadZX12R
03/14/11 2:25 PM
Even when my bike was STOCK kruz my bike thrashes Goody 08xjr1300 (muscle bike )without any problem since he picked my pcv dynoed bike up, he phoned my mobile in Tasmania to say it's got heaps of cohooners now and goes to fast for his liking ha ha it.s just so strange how the read out is so different from the others in the dyno part but when I took her out two days before my operation I was impressed with the way she goes now . ITS not really a problem just thought there could be a simple reason why the readouts are so varied
RE: Ping 1BadZX12R
03/14/11 4:57 PM
....Don't know Bean mate, looks like you may have been rooked, uhhhh sorry Rook. Seriously though, there are more variations in dynomometers than their are in bikes. You say you picked up 10 HP with just a PC5? I'd say that's pretty good,
+1
PSHawwwwww-- I wouldn't put all your faith in a dyno sheet. Just gives you an idear of how your bike stacks up against another bike that was tested on the same dyno/same day/same temp.
and +1 again
You got 10 hp off a PC and slipons?? That sounds like you must have gotten a great tune. AFAIC, the only reason to get on a dyno is for a tune. I'm not worried about the exact numbers for my setup. According to the creator of my map, it should yield +17 hp which is about what most full systems claim. I think the weight loss of a full system is at least as important as the hp increase. That's another reason to save a spot in the corner of the cellar for that stock header.
RE: Ping 1BadZX12R
03/14/11 5:00 PM
......far as the dyno,,,it's the dif between the ###, not the actual number itself. +10 means more than whatever the exact number is. Tight dynos, loose dynos, humidity, etc,etc,etc,,,,,,
RE: Ping 1BadZX12R
03/14/11 8:25 PM
Not a prob rook an kruz she annihilates my mates 2010 GSX750R, 04CBR1100XX, 2008& 2010XJR1300 & 08 R1 WITHOUT ANY TROUBLE I suppose I should be happy with 165 HP @ rear wheel as it,s 41 hp more than my 2004 CBR1100xx, IT would take something with a lot of extra $$$$$$$$ to leave me in the dust LOL just a spoilt big kid (really at 5'7" small) he he and no kruz thats with !
RE: Ping 1BadZX12R
03/15/11 6:53 AM
My apologies mate, I must have missed the Leo Vince pipes in earlier photos, I thought you were talkin about gutting the stock pipes. Bike looks great and I wouldn't worry about the dyno numbers unless your mates are testing significantly higher on the same dyno, same day. Some dynos just read high, we call them "happy dynos" and others read a bit low. Operators love dynos that read on the optimistic side, it sells their tune and pleases customers. Bottom line is it sounds like your 14 really hauls the mail and that's all that really counts.
G'day mate!
RE: Ping 1BadZX12R
03/15/11 7:00 AM
Amazing Bean how that picture could have come right from my area, everything looks familiar. I'd probably feel right at home down under.
RE: Ping 1BadZX12R
03/15/11 4:26 PM
CHEERS kruz Similar looking suburbs hey kruz that's what I was wondering how USA living areas are like the same but you guys drive on the wrong side of the road LOL
RE: Ping 1BadZX12R
03/16/11 7:01 AM
Australia looks much more like the U.S than old blighty does Bean, kind of a new world vs old world thing. It appears to be pretty flat terrain there, you got some good twisty roads outside of town?
Brenny
Brenny's Gravatar
Perth, Western Australia
RE: Ping 1BadZX12R
03/16/11 7:31 AM
Except for one major difference, we ride on the left hand side of the road
