@DragKing, the bolts and gaskets on the rocker cover are fine, just slip a thin 10mm washer under the bolt heads and torque to spec.
Already did it. I was getting the valve clearance check done so I ordered new bolts and gaskets
It's kinda of anal but I rather have every bolts tightened in the right sequence etc... I run my finger down there once in a while and it's dry, not even a hint of moisture.
Also, the only upgrade I'd do for this year would be a Two Brothers black series slip-ons. Would I need a power commander for that? I had a PC5 in my last bike, I should have taken it out before selling....
Why slip ons? All that money just for sound! Just get a full system Akrap, Brocks or Hindle.
Mine came with D&D slip ons then I got rear ended and upgraded to Muzzy's slip ons, it was a big mistake for that money I could have gotten a decent full system. The insurance paid for it so it's all good. Sorry back on topic, I ran my D&D's and Muzzy's for more than a year total and the bike was fine. I ended getting a PC5 just to milk a little more power and smooth things out since I took the flies out but that it's a whole different topic lol
P.S. A full system will make the bike run cooler
@Kruz: 2200 miles!!! That's not even an oil change. Get the Rosso Corsa and have somebody take a look at your suspensions. I'm not sure but I think I've got a little more than 4k on my rear and way more on the front. My mechanic says I have at least one more k on it so I won't even change it before I head to the sisters! I do a lot of commuting with the 14 and you probably spend more time on the sides of the tire than I. Buying a cheaper tire that last only 2200 miles is false economy!
* Last updated by: dragking on 6/2/2012 @ 11:56 PM *
