Thread: info about slipons ???
Created on: 12/17/12 04:06 PM
rocketman
12/17/12 4:06 PM
so someone help me out about 2012 mufflers......
does the center collector have a catalytic converter ?
does each muffler have a catalytic converter ?
if i put any kind of aftermarket mufflers on they will pop on deceleration ?
at inspection do they put a air-tester in your mufflers ?
is a 4 into 1 slip on made and would that help on the decel popping issue?
THANKS FOR THE HELP !
ryanc
ryanc's Gravatar
RE: info about slipons ???
12/17/12 4:29 PM
does the center collector have a catalytic converter ? Yes
does each muffler have a catalytic converter ? Yes
if i put any kind of aftermarket mufflers on they will pop on deceleration ? Most will get it tuned to suit the mufflers/ system.
at inspection do they put a air-tester in your mufflers ? Where are you located ?
carabuser
carabuser's Gravatar
12/17/12 5:16 PM
If you get a 4 into 1 you are going to need some kind of fuel managment, power commander etc .. that will probabaly get rid of the decel, along with plugging the airbox, and hose that goes to airbox, I have slip ons,and I plugged the airbox and hose and was still getting some decel pop, only thing that helped was I put the quietest noise inserts that two brothers makes, that helped the decel pop a lot, mine is a California model, I dont know if that matters, but I think it has extra emissions crap on it, more so than the other models
Predator Race Team #14
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
SparkyG
SparkyG's Gravatar
12/17/12 6:08 PM
Ive got a 2012 model and when i removed the exhaust, I did noticed that there's no cat in the mid pipe only on the muffler pipes.
I went with a four into two, into one, form Akra and also did the Block-off plates and a PV5 so far no popping on decel, as far as the inspection, like ryanc stated it depends on your location, hope it helps.
* Last updated by: SparkyG on 12/17/2012 @ 6:09 PM *
2012 ZX-14R Full Akra exhaust,PC5, Puig smoked screen, bar risers, lowered pegs, Quick shifter, fender eliminator, steel braided lines, Driven aluminum sprocket and hand grips.
12/17/12 6:22 PM
The Euro and Aussie spec bikes have a cat in the collector... US spec bikes do not.
12/17/12 8:37 PM
"The Euro and Aussie spec bikes have a cat in the collector... US spec bikes do not"...KEEEERECTO!
Neilp
Neilp's Gravatar
Brisbane, Australia
12/17/12 10:45 PM
I agree!
With this cat in the collector, there is very little popping. It is why I have not upgraded the headers!
Neil
SparkyG
SparkyG's Gravatar
12/18/12 5:52 AM
Good Info gentleman,I had no idea that the EURO bikes had a cat in the collector...learn something new everyday
Full
Full's Gravatar
12/18/12 8:35 AM
yes ! euro bikes have cat too :)
carabuser
12/18/12 10:15 AM
Are you sure there is no cat in the header on US models ? manifold-comp-exhaust 39178-0174 is US part number and the service manual says that it has a cat in there, but no Oxygen sensor I think it pages 270-271 will try and post pictures later ....
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
carabuser
12/18/12 2:12 PM
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
12/18/12 3:44 PM
I haven't cut open one yet but Ivan has and found no honeycomb.
SparkyG
SparkyG's Gravatar
12/18/12 4:41 PM
If you look at post #4 I included a picture of my ZX-14R header that was removed to install the Akra full System, the only thing in the collector is a divider...that's it.
Looked at the headers and nothing either, so I guess the cats are only in the mufflers themselves, unless I got one that was put together on a Friday afternoon lol..
Neilp
Neilp's Gravatar
Brisbane, Australia
12/18/12 8:27 PM
The Euro bikes have to meet Euro 4 emissions I think this is one of the toughest emissions standards in the world to meet.
12/18/12 9:02 PM
Don't know where those page numbers came from...certainly aren't in the service manual I have...2012 zx14R.I checked my headers(from my 2012)...only that separator plate...no cat.
I googled those part numbers...in all the sites that have that parts diagram(several)...none show a cat in the collector OR the mufflers...IDK where that pic came from?I do remember seeing a schematic of the mufflers and headers...they showed the muffler cats in em.The header?I don't remember seeing a cat in that part of the diagram.And I remember being 'relieved' that I wouldn't need to cut the collector open to remove a cat.
* Last updated by: Grn14 on 12/18/2012 @ 9:21 PM *
carabuser
12/18/12 9:27 PM
Got the picture from the online manual from this site, the part number says it has a cat, I dont know maybe a misprint, because someone said Ivan cut one open, and there wasnt a cat ?
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
ryanc
ryanc's Gravatar
12/18/12 10:42 PM
Dont the american bikes come in a couple of dirfferant emission specs, California is stricter or something like that?
12/18/12 11:47 PM
THAT could be.Mine didn't have one in the header.
