Thread: need help finding these rubber grommets
Created on: 04/23/14 06:40 PM
bentz69
04/23/14 6:40 PM
both of these grommets broke. anyone have part numbers for them?
2011 zx14
RE: need help finding these rubber grommets
04/23/14 7:41 PM
I think you are referring to these:
Part #92015-1757
$5.44 each
Part #92015-1692
$3.81 each
2010 ZX-14 MotoVlog
04/23/14 8:44 PM
Did the inside portion tear off when you removed them? If so, remove one airbox bulkhead door under the fuel tank. You can reach toward the back where the 90 degree angle catch trough is runs left to right before the air filter. Pick them out.
Those wellnuts (or any well nut) break when you tighten them too much.. All you need is finger tight on a wellnut, maybe a half turn more on the larger ones. Just enough to squeeze the grommet a little bit. The rubber absorbs the the vibes ansd the screws won't loosen under the slight tension of the rubber. Use blue locktight on the non-wellnut fasteners such as the ones at the botom of the lowers. Those come loose. NEVER use loktite on a well nut or the grommet might just spin when you try to remove the screw.
BUSAKILLER1987
BUSAKILLER1987's Gravatar
slidell, louisiana
04/24/14 7:50 AM
Kawasaki parts warehouse. It's pretty much the same catalog as the dealer. Part #'s and pricing
1975 Honda 754 super sport
2001 yamaha yz250F
1975 Honda cb 360
bentz69
04/24/14 9:47 AM
thanks fellas. i ordered from http://desmoparts.com fraction of the price of oem
yea the wellnut broke in half and fell into the air box. got it out no problem
2011 zx14
