I was reading about the new production motorcycle land speed record set recently at Bonneville with a ZX14R. When I got to this part, it occurred to me they hadn't actually run a production ZX14R -
So Broomall started engineering. Since the class allows displacement up to 1,650cc, the cylinder bore was increased 2mm and the stroke lengthened 3mm for a displacement of 1580cc. The usual hot-rodding tactics were applied, such as polishing ports and changing cams, and the ECU was modified to allow unlimited top speed. The exhaust was altered internally, though it had to retain its stock look on the outside, under the rules. Sprockets were changed for taller gearing.
And they filled the hollow swingarm with lead to dampen rear wheel vibration in rough spots on the salt flats.
So it wasn't actually a production ZX14R.
Considering that Dublin Kawasaki ran a street legal, CA plate wearing, ZX11 over 200mph at Bonneville in the early 1990s I'm not impressed.
