Thread: useless post but i had to say it to get it off my chest
Created on: 02/25/09 12:02 PM
ZXtwitch
ZXtwitch's Gravatar
02/25/09 12:02 PM
So today I pulled the plastics to install my block off plates. and while doing so I decided to check the infamous well nuts. and of course there bad. so back in the car I go to buy some more. I love this bike but I HATE WELL NUTS IN THE AIRBOX!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
there I said it. I'm better now thanks
07 black and blue tear away 14, brock's parts: alien head full exhaust, front end strap, ceramic wheel bearing, brock's quick change lowering links. pulled flies, speedo healer, muzzys timing advancer, muzzys block off plates, K&N,+1 rear, pirelli and the list goes on but is classified from there.
kawnow
kawnow's Gravatar
RE: useless post but i had to say it to get it off my chest
02/25/09 1:42 PM
They do suck. I just replaced mine with hardware store ones. They were pretty cheap and they work also had to use some rubber washers on top of them.
lytnin
lytnin's Gravatar
02/25/09 1:52 PM
5mm or 6mm?
Bud0212
02/25/09 1:53 PM
I think everyone agrees, they stink. The only problem with useing the cheap hardware store ones(at least around here), they are standard, not metric.
hoopie
02/25/09 2:18 PM
I wonder if my nuts are well? :)
Seriously though, What is a well nut?
2008 Kawasaki ZX14 Saphire Blue. Yosh R77 Full Titanium Exhaust, Power Commander 5, Custom Map, TRex Frame sliders, MRA Touring wind screen, Speed Tactics fender eliminator, Heli Bar Risers, Lawst cause frame plugs,Ketie Tank Pad
ZXtwitch
ZXtwitch's Gravatar
02/25/09 2:26 PM
Hoopie well nuts are ever where on the bike however the oner in question are the top rear most nut that the foreman grills screw into. it is basically a rubber grommet with a nut incased in it. and if you don't thread the screw into the nut exactly right it can push the nut out of the grommet. the can also tear with time. this normally wouldn't be a major issue and not a huge ordeal to fix but on a 14 if the back half of the well nut rips off it falls into you air box. which goes with out saying is bad.
Lytnin there 5mm well nuts.
02/25/09 4:37 PM
Hoopie I hope that your nuts turn out to be ok and don't fall in your box ......... Not being serious , but that's some funny sh.t. TEEEE HEEEE .Sorry but that one has me in stiches .
ZXtwitch
ZXtwitch's Gravatar
02/25/09 6:39 PM
yea its funny till you discover YOUR nuts have fallen
Zerk
Zerk's Gravatar
02/26/09 7:23 AM
Here is a solution to the cheesy well nuts....LINK
The metric kits with the setting tool run about $80.00 - LINK
These kits are handy to have around and I always find uses for them in some project or repair.
* Last updated by: Zerk on 2/26/2009 @ 7:27 AM *
kawnow
kawnow's Gravatar
02/26/09 12:00 PM
I don't know about using a metal insert into the frame possible stress area for that cast frame. These are 6mm well nuts bought from a Ace hardware store. Not sure where the washers came from but without them the body panels did not fit flush. I superglued the wellnut in place and the washer on top.
Zerk
Zerk's Gravatar
02/26/09 5:20 PM
They are available in steel, aluminum and, poly kits. I haven't actually seen or put my hands on the the poly style to see how tough they are but, I have used the aluminum in plastic before with excellent results.
This bike seems to be loaded with well nuts everywhere possible. I've only had my bike a week but the few things I've messed with were all held on with well nuts.
I think I'll order some metric poly inserts and see what they're like.
02/27/09 3:32 PM
Every time I take the bolts out I worry . But I still have done nothing about it . It always seems to be something that I tell myself I will get to later , but then you know ,later never comes . And your right,I won't think it's funny when they fall .There will be no laughing then . More like crying . The wife rides a 2008 250 ninja and on her bike I had to replace most of the well nuts . They were all cracked .
