Thread: Micron Serpent Owners
Created on: 06/20/11 06:09 PM
soulja
soulja's Gravatar
06/20/11 6:09 PM
Micron Serpent owners, what map are you guys using? Custom? Power Commander told me to use the Muzzy Map, but now that I have an ATRE, I am wondering if I should be using the Muzzy No Flies map. Any thoughts?
"The Truth (Gospel) kills pride. I call it my "Swagger Dagger"
Pro
buck20
buck20's Gravatar
RE: Micron Serpent Owners
06/21/11 12:23 AM
I have the Micron Serpent system, I didnt jack around I just got a custom map with a dyno run. I think the key is to get it how you want it and then have it set up using a dyno and then stop messing with it and ride it! But thats very hard to do.
To much to list!
06/21/11 4:33 AM
There is great truth in that statement!
Since Brock Davidson talked me out of buying a PC5 and into buying a PC3 pre-loaded with the track map they've developed over the last 3 years or so, I've been able to just ride and ride and ride, with no cares.
It works, it works good, and I don't have to mess with it at all.
Which doesn't mean I won't, but I won't have to.
* Last updated by: privateer on 6/21/2011 @ 4:34 AM *
soulja
soulja's Gravatar
06/21/11 12:36 PM
How about a PCV and Autotune as compared to a custom map?
Pro
06/21/11 3:01 PM
You would have to constantly hook your laptop up, build the change table, merge it in (someone correct me, I only read about 1/10th of the PC5 instruction manual lol)to get the changes.
The pre-done map is usually good enough for 99% of us. At least, Brock Davidson's maps are. Soon I'll know if the FAIC map is.
My riding doesn't change. If I rode a lot of sport touring, and then frequently did track days or drag racing, I'd want a PC5 to keep multiple maps than you can just switch between.
But for me, practical riding, the map that came with my Brock's CT-Dual exhaust system and PC3, is way more than adequate for me.
Hence, I never spend one minute messing with the piggy. It just does its job and doesn't require my attention. Thats how I like things.
