Thread: Super cold coming in my area
Created on: 01/04/14 12:03 PM
ZX14MAN64
ZX14MAN64's Gravatar
01/04/14 12:03 PM
Down around and even below zero over the next couple days.
What are you doing to protect your machine from the cold?
RE: Super cold coming in my area
01/05/14 9:01 PM
Checked anti-freeze and have in garage batteries on maintainers. Should be good to -40 at least. won't get that cold in and enclosed building, even w/out heat.
even if it does, the antifreeze will probably not form solid ice until much lower than the anti freeze protection shown by a float test.
Cornelius
Cornelius's Gravatar
University of Okoboji
01/05/14 9:52 PM
It's gonna be -30 tomorrow here and mine is in cold storage right now, I'll do nothing about it. She is just fine as long as you pull the battery, unless you want to buy a new batt leave it in and let 'er freeze and leak acid in the compartment. Also long as your coolant ain't a decade old that should under most circumstances be just fine. It wouldn't hurt to get a float tester from an auto parts store to check the condition of the coolant.
2013 Super Fast SE ZX14R
