1. Live with it or buy/find stock pipes.
2. What rider345 said.
Here is how it works.
Stock - Upon throttle close the fuel setting turns lean down to 18 AFR, for argument sake.
TRE - The bike turns rich on decel, adds fuel to a 16.5 AFR setting. This helps, but you lose maps: which make the bike run/feel smoother. There might be a twitch to the throttle with the alteration. Some like the peppy feel, others prefer smoother running.
PAIR works like this.
Stock - The air actuator adds clean air from a tube inside the ram chamber.
Stop - The air from entering, which causes fresh air to keep igniting the unspent gases, causes the pop or that reignite to happen. This will simmer it down some. Pull the [only] hose under the frame that snakes up from the front valve cover hoses to the hose under the frame's belly. If there are 2 hoses under the belly [we enter the newer gen model], again, start with the hose at the front of the valve cover and follow it up. Cap off the hose, cap off the ram's hole. Let the actuator run or a code will be set if you remove the connector.
I might try a resistor combo setup so the light goes off fandango. Maybe someone may have that figured out by(pass) now?
