Anytime there, Kruz. I'm not worried either. Just for grins, when I looked at the gap from the pressure plate to the friction, I could not push the "L" part of the probe's head in between those 2 points. I would guess about 1/8" gap is the width, if I push the disc away from the pressure plate.
With the lever out, I now have the outer edge of the pressure plate even with the tang's outer edge. But after 10 plus thousand miles, she would stick out a little farther, when it was new that is. Try this next. I just took the probe's pointed end this time, dug into the pressure plate and she moves effortlessly... sans the oil drag between plates.
This tells me I have zero plate warp > Dragging the steels, as the frictions remain stationary. Then I placed the bike in 1st gear [rear wheel off the ground] and jacked the back wheel, until I could move either the gap between the clutch tangs, or the outer ring gear to the cranks mating gear. Again, this tells me, we are chasing rivet elongation, where the whole friction and steel assembly would move back and forth, the basket kind of lagging behind and not the tight, zero gap... sans now, the tang of the frictions butting up against the clutch outer's two tangs or that channel for each friction tang.
With a tight clutch outer, the friction's tangs can never move the outer basket. If we are chasing a noisy clutch system, then we can move the outer basket, because the riveted gear is going nowhere with the crank not moving. So, the probe is more a friction to steel drag issue. The static 1st gear, rock it back and forth to watch the elongation of the basket moving, or the frictions just moving in their channels, without hearing the crank move.
What is cool about the oil fill cap being off is the echo chamber noise added to the wheel movement running the chain slack up. That is one sound you have to block out, because the crank is the next sound. The crackling of the basket is another sound. You have a lot of noise to filter out and then filter in to pinpoint a certain noise at certain areas.
So, if you watch the action just with the cap off, eliminate the basket, plus the gear noise, that clutch outer is going to be so flimsy and floppy looking, you found the problem watching the basket buck back and forth on it's own. If you feed the clutch with one hand and move the back wheel with the other hand, she should look as tight as a drum and no movement; you keep collapsing clutch plates onto each other slowly and move the back wheel, [back and forth] to watch every little tolerance stay in place. Then, it is not the needle bearing. If the rear wheel's drive chain moves the basket so as not to move the crank, you'll hear the noises once you hear the moves made> Pinpointing which one? I went back to check, so this might be your guide matching moves/noises made on my end. Try it on your end, then you can forget about that noise for now.
