Could the tire be mounted in the wrong direction?
Naaaaa. Even if it was, it's the internal folding with an inner and outer layer, that has vulcanizing written all over it? I doubt you will pull that fiber away from that fold over, well before you wear out the tire in another 3 thousand miles. So really, the direction does not matter in a wobble type condition. Let's narrow this down:
1. Yes, the tires were change as a set*** = Both have even rolling wear, though one wears different than the other, obviously.
2. No, the tires were change as the rear was still looking good so I just changed* the front* with 600 *miles on the front right now.
3. 36 PSI is a solid variable with a soft wiggly front carcass. 42psi up and re-ride the same input you made to shake the suspension up. No, the steering neck shock, should be turned down and as ride-able for the slowest of moves; You want that psi to talk quick on the lightest hand gesture. Once that variable clears, meaning, it still wobbles, then you begin to keep clearing what questions I keep compiling for you;
4. Yes, I use the same profile matching tires.
5. No, I could not pass up the deal on this tire, so both mismatch as we speak.
You hear about this arc on the road for rain being that roll-pitch? How come when they lay asphalt, they use a flat rolling pin kind of vehicle to lay the tarmac down? Are you banked over to the left or right that much on the road to make that kind of arc on one side of your tire? Do I believe that? I go to my car tires, I see the edges gone because I throw it in the corners and it's on that edge of the wrinkle, yeah. Other than that, there is a lot more wide to arch around the road having a car tire in place, how come that profile is flat across the wider tire? How come your tire is rolling over when that flat rolling pin was smashing down flat, a hot goo? Show me the arch of the triumph rolling pin is pizza has an arc too, right?
So, inside the rim, look through the disc, look for the arrow direction for the rim to clear that rolling off center to the fork.
Sharkey, This is typical game of chassis setup or we are in a tuning setup, I ask BAD to choose a number so we can continue the tune. I'm trying to weed out the stereotypical wobble, choose a number or pick the best combination of numbers. I see a wobble in the making. There can be so many variables with new, used, half this with half that is just walk this; as one chess move at a time. What is your tire setup? Time on both tires? And without more info on your end, look how raw BAD's rear end is looking right about now. Those were just a few saddle up questions going in here.
Waiting for a number(s) game from you now, Sharkey. Think I'll go an start up the BADBQ with a post toast teas, just to see if he picked a number yet or is still picking his... _______________ Fill in the blank.
