Went and did it. Made it down to the Honda East Toledo open house and made a dyno pull. My 2012 14r, 55xx miles. No power mods. Its the lowest stock dyno pull Ive read about. BUT several other bikes seemed a little low as well.
Dynoed in 4th gear. Lowered to 35 psi in the tire, I have read it should be 30 to prevent slip? No TQ reading for a cheap, quick pull. 20 bucks. Made 179.56. SAE. Smoothing 5.
Conditions 83.17 degrees f, 29.53 in-HG, Humidity 35%, SAE 1.01.
So is it low due to SAE? or just a stingy dyno? most of the runs I have seen have always been 183-4 to as much as 195.
My friends 1st gen FZ1 only made 112.5. an 08 BMW k1200s made 136 with a slip on. another 14r with 2 bro's slip on's and wrapped pipes made 185ish? and an 07 Gsxr600 made under a hundred. 99.x. should be 105, right?
am I just being paranoid?
