Thread: GenMar Riser Problem
Created on: 12/22/12 09:29 AM
streetracer
streetracer's Gravatar
12/22/12 9:29 AM
Picked up a set of GenMar risers and installed them today on my 2012 ZX14R. The risers fit fine but the caps wont go in the clip ons. They go in about 1/4 of an inch and stop. Tried gently convincing them with a rubber mallet but that didnt help. Anyone else have this problem ???
Just came back from a 50 mile ride and the risers feel perfect !!!
* Last updated by: streetracer on 12/22/2012 @ 11:25 AM *
SparkyG
SparkyG's Gravatar
RE: GenMar Riser Problem
12/22/12 12:03 PM
No...no problems with mine, pushed them in until the hit the o-ring seal
* Last updated by: SparkyG on 12/22/2012 @ 12:05 PM *
2012 ZX-14R Full Akra exhaust,PC5, Puig smoked screen, bar risers, lowered pegs, Quick shifter, fender eliminator, steel braided lines, Driven aluminum sprocket and hand grips.
streetracer
12/22/12 1:36 PM
Your cap insert is different than mine. I will check with GenMar and ask if I have the right caps. Thanks for the pics !!
12/22/12 2:01 PM
Why even use them? They prevent access to the preload and rebound damping adjusters.
SparkyG
SparkyG's Gravatar
12/22/12 2:57 PM
Actually....No, the center caps snap on and off allowing for adjustment's to the suspension like preload and rebound damping.
12/24/12 7:52 PM
Some are silver.
12/24/12 9:03 PM
The covers I got with my ebay specials don't go all the way in either. I just tapped them in and left well enough alone.
streetracer
01/02/13 7:01 PM
Gen Mar emailed me to get a few measurements from my bike. They had me measure the I.D. of my clip ons and they are going to make me a set of caps to fit no charge. They are a class act !!!!
01/02/13 8:21 PM
Happy for ya...but I'm a bit confused about HOW the caps wouldn't seat...the little pointy thingies only go in about 1/4 inch or less...and that's all...the cap doesn't actually go flush with the genmar flange.It stops at the cap flange part.Shouldn't ever have to pound the cap in...you can push it in there with your fingers and hands.You just either pull or push those teeth in or out for your desired fitment tightness.This is weird=0
You see that pic in the center...there's a smidgen of cap sticking up...that's supposed to be like that...it's bigger than the ID of the genmar...on purpose...you pop a sharp screwdriver(or something similar that won't scratch the genmar finish) under that 'lip' to remove.Otherwise...it would go all the way in...you'd have to remove the genmar to get the cap out.It's made to be accessible so you can adjust the preload.Then recap.
* Last updated by: Grn14 on 1/2/2013 @ 8:25 PM *
streetracer
01/02/13 9:32 PM
GRN14: When I say "cap" I mean the sleeve that the pointy thingy goes into. The sleeve wont go down into the clip ons likes its supposed to. Please see the above pictures.
01/02/13 10:34 PM
"GRN14: When I say "cap" I mean the sleeve that the pointy thingy goes into"...okay...I see what you're saying now.....sorry.
I didn't use the sleeve on mine.I think it's an option for whatever reason.Mine fit nicely and capped up without that sleeve in there.I didn't like the look of it sticking up past the clip-on surface.I would 'guess' that sleeve is so you can 'easily' get a screwdriver edge or something straight in under the cap,as opposed to angling the driver down and 'popping' that cap off that way.If you're careful...you won't scratch the surface.Course,if ya slip or something...it's on you I always used a teensy flattip screwdriver to get the caps off.Long as ya don't have those tines holding the cap in too strong...they pop right out.
* Last updated by: Grn14 on 1/2/2013 @ 11:21 PM *
SparkyG
SparkyG's Gravatar
01/11/13 8:25 PM
Streetracer...any word on your issue with the risers, did they make you a new set and do they fit properly?
streetracer
01/18/13 4:59 PM
SparkyG: Received an email from GenMar today that the new caps are in the mail. I will let you know how they fit when they arrive.
streetracer
01/23/13 8:30 AM
Received my new "smaller" caps from GenMar and they fit perfectly. Thanks GenMar, you are a class act !!!
SparkyG
SparkyG's Gravatar
01/26/13 10:59 AM
Glad to hear Streetracer...hope you're enjoying them.
