Thread: Accosayto Master Cylinders ON SALE!!
Created on: 12/15/13 10:55 PM
12/15/13 10:55 PM
oops- I meant ACCOSSATO
The nonadjustable 19x18 is also on sale for even cheaper. Brembo my
* Last updated by: Rook on 12/15/2013 @ 11:03 PM *
RE: Accosayto Master Cylinders ON SALE!!
12/15/13 11:02 PM
you will need to hook up a fluid pressure switch to retain the functioning of the brake light. No biggy. nother $7-$16 depending on what kind of lines you have to the MC. you can use the stock fluid res with the 14.
* Last updated by: Rook on 12/15/2013 @ 11:18 PM *
zx14beast
zx14beast's Gravatar
12/16/13 7:12 AM
Cool, nice find Rook....
BTW, did you get my PM??? about your wheels?
12/16/13 8:05 AM
No I did not. zx14beast. perhaps you forgot to hit SEND. ....or maybe you used the member list and accidentally chose the guy above me? ah well, send again or start thread. ...or just ask here. I have a hunch there is not going to be a huge reaction to this topic anyway.
12/16/13 3:40 PM
how do they stack up against the brembo, they look good
12/16/13 4:59 PM
I did a search and the Accossato got mixed reviews. Some said it was every bit as good and others said it was lower in quality than Brembo. Personally, I think the lower in quality idea is just because Brembo is such a well known brand and widely accepted.
The Accossato is as expensive (maybe a bit more). Looks like a copy design of the Brembo. Accossato has 3 adjustments and Brembo has 2. Accossato adjustments are more sport and track oriented (20 is supposed to be good for street, 18 for track. The Accossato goes to 17 which I can only assume is even more aggressive).
Here is the thread over on busa.org if you are intersted inclicking some links to articles I found. I'm mythos over there, BTW.
