I am getting a real bad backfire at around 4,500 RPMs. I was told to plug the hose running from the top of the headers that runs to the airbox.
I have located a Gray hose (the only hose) running into the bottom of the airbox...is this the correct hose to block off? It is about 6 inches long and runs into a plastic piece above the headers.
I want to be certain before I RTV this plug into the hose.
Thanks
2010 Special Edition Black/Titanium. Muzzy M10 Full System, PCV, F.A.I.C Map, NGK 9EK plugs, Vortex Shorty Levers, Vortex Rearsets, Vortex Rear Sprocket (43T), SpeedoHealer, EK ZZZ Chain, K and N Air and Oil Filter, Fender Eliminator, Smoked Rear Turn Signals, Galfer SS Brake lines (front and rear), Carbon Fiber Ram Air Covers, Custom Airbrushed Front Cowl, Driven Grips, Secondary Flies removed , blocked PAIRs and LC frame plugs.
