Status:
Just installed the TiForce w/ Carbon can. The exhaust is from a pre-2012, so I wasn't sure if it would fit without incident. Well, it fits PERFECT. I've heard rumors that the pre-2012 exhausts would need to have the radiator bracket moved out a little for clearance, but it wasn't actually touching once I reinstalled everything. It was very close, so I installed two small washers between the block and the bracket for piece of mind. The exhaust went on with Zero issues. The TiForce exhaust is absolutely Gorgeous. Very Nice Quality & Finish.
I cranked it up and it purrrrrrs like a kitten....a very big, angry kitten, and I think my neighbors are going to hate me every morning. Once it drops to idle, its not too bad. The biggest problem I have is that EVERYTHING in this compound is concrete with open garage ports, the reverb is killer(But sounds So Bad ass.) I didn't take it for a spin yet, going to install the PC5 and upload a map from a Full 2012 Yoshi system that someone sent me until I can get it dynoed correctly.
I did install the GPRv4 damper yesterday, and I forgot just how nice they are. The bike feels so planted at all angles now. I know there are a lot of opinions on dampers, but I think a damper makes this bike (and the other two Ninjas) that much better. Would be nice if it actually came with a factory damper, but I'm stoked. This is the first stem/Scott's type I've ever had and I Love it. It gives the bike a much cleaner look and the install was all of 1o minutes. I can't say the same about the hyperpro ashtray contraption I had on the ZX12 or the hyperpro that I had on the 2006 zx14. There are also no issues with using Risers. Risers and the damper on my 2006 did not get along well...I was always busting the rubber washers. From what I've read, there is a fix for this problem.
The front fender will be swapped out to a zx10 fender in the morning also. I went ahead and bought a set of brackets to keep it simple. I've contemplated keeping the stock fender, but I just got to see it installed for myself. Besides, the stock fender is going back to the dealership to get painted because they scuffed the piss out it when they delivered it from Dubai.
As for the lights, I will install those tomorrow also. I have sylvania superstar somethings that I got for the low beams and LED corner lights. I'm still up in the air on what to do with the other lights I purchased. I will have to fit the fender and see how I want to mount the LED's---may not use them at all. I am also installing a red led strip on the bottom of the plate, but I need to fabricate a bracket. I think for now, I will just install the wiring...who knows.
I did manage to pull the front blinkers apart with a little heat and shoot them with a black so they will match the blinkers that I already painted. I would like to mount those LED's on the inside as running lights, but I'm still working on how to do it. The lights I ordered from ebay are a lot bigger than I planned. I have 4 days to figure it out.
[COLOR="Red"]I wanted to say thank you to Lee(Smokin'), Brock's, and 9/10ths for the help with figuring out the new fairings. Links=====>[/COLOR]
http://www.brocksperformance.com/Instructions/ZX14/996434.pdf
2012 ZX14R removing body work .. - YouTube
The 9/10ths | 2012 ZX-14r Manuals
* Last updated by: lie2me on 11/29/2012 @ 12:30 PM *
