My budget is a max of 7k but would prefer lower. From what I have found so far only the 06-07's are within my budget. I have read that these are not the most desirable and that there was a recall for cracked frames. A few other things I have read are related to the steering responsiveness and ride compared to the 08's and up. My understanding is that the 08's and up are better choices. This being said, I found this one but would like some advice. not only on it but also any other things I should look at before dropping the cash.
Hi, sc. If I were to sell my 08 with 47k miles on it, and i wanted to sell within a month, I'd be asking no more than 3k if I returned it to stock. I doubt very much I'd get $6000 even if I had a year to wait for a sale. I would have sold for 6k back in 2012 when the bike had half the miles. i am sure if you find someone who really needs to sell the bike, they'll let it go for $3k or even 2k. My 08 runs as good as new at 47k miles. The compression test I took last summer showed that it was at the minimum of spec but I can't tell by the seat of my pants. I'd say it's a long way away from needing new rings.
There's no problem with the 06-07s compared to the 08-11. The frame recall was not for a weak frame, it was a simple bolt re-torque. You could do your own if needed. The 06-07s supposedly made a few more hp and were a few lbs lighter. The 08-12 had finer spraying revised angle injectors and revised piston dome and revised fueling and flies open which is all pretty mute once you remove the flies and tune. Everything else is the same between 06-07 and 08-11 except for some very minor parts updates like air cleaner cover. The 2010 might have had some fueling changes but again, if you are going to use a Power Commander or flash, that will be overridden anyway. The Gen1s are essentially all the same except for colors.
I'd look for one with 24,000 miles, any year. If you can find one with under 10k miles, that might be worth an extra couple thousand but I wouldn't pay 7k unless it had under 3k miles and was in mint condition. You might find that in a 2011. If you can't find one cheap, a brand new one starts to look pretty appealing as long as you are sure you'll keep it a long time.
That's a fairly low miles '06 you're looking at. I'd say if you want those mods, that's not a bad price. Bike=$4000, mods half value for used (even gently used, sorry it's half --that's what I pay and sell for) =$2700. See if he'll knock a couple hundred off.
2024 ZX-14R bran friggin NEW!
