Is it terrible if all of us are spied all the time? There are many satellites in the sky that are watching on us at any moment, no matter what we do, where we go, all could be tracked down by GPS device. And GPS devices are very common now, it could be bought everywhere at very cheap price. That means, bad buys could track us down by a small GPS device only, and it is easy. Think about it, our family, our company, our children, our friends, all of them will face the same danger. How to protect us from the tracking of GPS device? GPS jammer could help us. GPS jammer is a high tech device designed to block GPS signal, thus disable the GPS service in a certain area. It could issue a stronger signal to cover the GPS signal, so the GPS device could not receive it, thus show No Signal and can not work. But after you turn it off, all GPS devices will resume working in a minute. It is easy to use and will not do any harm to the GPS devices. Below is a very good GPS jammer, from which we will know more about the GPS jammer: the High Power Portable GPS and Mobile Phone Jammer, with model number S802001.
If you need to buy a GPS jammer--also called GPS blocker, what kind of GPS jammer do you need? Desktop or portable device, single GPS jammer or multi function jammer, which one is important to you? If we have a jammer that could include all above features, do you want to have one?
It is a powerful, portable GPS jammer and cell phone jammer. It could jam the following frequencies: CDMA (851MHz-894MHz), GSM (925MHz-960MHz), DCS (1805MHz-1880MHz) and PCS (1930MHz-1990MHz), 3G (2110MHz-2180MHz), GPS (1500-1600 MHz). The anti GPS tracking device can jam the GPS signal to protect your important event and you can enjoy your communication in your car. The jamming range radius for GPS is 15-20 meters and for mobile phone is 5-10 meters. With DC4.2V/4800mA/h Ni-ion battery, the continuous using time is around 90 minutes. You can charge in any place with AC charger and car charger.
This high power portable GPS signal jammer and mobile phone jammer (CDMA GSM DCS PCS 3G) helps you to keep a safe and peaceful life. If you want to enjoy more choice, please click the jammers and you will be satisfied. If you want to know more, please refer to the product features and specifications.
Technical Specification
Power: CDMA:25dbm GSM25dbm DCS:25dbm or PCS:25dbm GPS:23dbm 3G:23dbm
Frequency: CDMA(851MHz-894MHz) GSM(925MHz-960MHz) DCS(1805MHZ-1880MHZ and
PCS(1930MHZ-1990MHZ) 3G(2110MHZ-2180MHZ) GPS: 1500?1600MHZ
Automatic power switching power supply: 50 / 60 Hz / AC 100 ~ 240V transmitting to DC12V
Jamming range: Radius 15-20M for GPS, Radius 5-10M for Mobile Phone(depend on cell phone signal)
Battery: Ni- ion battery DC4.2V/4800mA/h
Continue using time: around 90 minute
Size: L110 x W62 x H30 mm
Total output power: 1200mW
Weight: 300g
Package Contents
Jammer
4*Antennas
AC Charger
Car Charger
