EK ZZZ was the way to go some years back. That model was superceded i guess but given the reputation, I'd go with it. Almost never needs to be tightened unless you change sprockets. Mine's got about 36000 miles on it. Still looks new. Have not measured stretch yet but i only tightened a tiny bit about 3 times. Weighs a tiny bit less than OEM and much stronger.
Sprockets, you can go with any brand you want for aluminum. Use a steel front, it will wear out about the same time you need to replace the rear which is better than you replace the front and then you need to replace the rear 8000 miles later. Replace all at once, you only have break in wear once. Replace one part at a time you go through break in 3 times, wear on all the parts that should have worn in once. Vortex is the lightest rear I know of. Any steel front but i used supersprox and it has been good to me. Also used AFAM rear sprocket...wears about the same as Vortex alum or any other alum sprocket, I'm sure. If you can find an aluminum front sprocket, don't use that. It will wear out in no time.
Make sure you get all parts in the same pitch. I don't want to give out misinfo on this so I will not mention the pitch number but I will say, stick with stock pitch. You can go to a smaller pitch and save weight but most will tell you, that is not safe for a hyperbike even if liter bikes make the same hp, they don't have the tq.
* Last updated by: Rook on 3/4/2017 @ 7:13 AM *
2024 ZX-14R bran friggin NEW!
