Thread: Help, need source for well nuts!
Created on: 10/22/10 06:44 AM
zx14drew
zx14drew's Gravatar
10/22/10 6:44 AM
Ok guys, someone else had this issue, but the discussion did not appear to resolve the issue:
A large rubber well nut was cut nearly in half and needs to be replaced... It is the larger rubber/brass well nut that secures a corner of the foreman grill to the fuel tank/airbox assembly via a longer than average fairing machine screw and is NOT the smaller more common OEM schematic part number 92015 (5mm) well nut as shown at such web sites as Babbits, this is a Kawasaki error in its parts diagrams I guess, this fuel tank well nut is much LARGER, outter diameter of rubber is much larger than the common 92015 well nuts that secure most of the fairing and windscreen bolts.....I need your help in finding a source and or correct part number for the larger mystery well nut..
ANYONE:
a) What is the OEM ordering part number for for this larger fuel tank well nut that seats the long bolt through the upper corner of foreman grill in to the airbox/fuel tank housing (on the larger OEM well nut I took out it says 1420D, but thats not an OEM part number. It is NOT 92015 as shown on OEM schematics such as at Babbits, unless there are differant version of 92015 well nuts (like 92015 - xxxx)??????
b) Where can we order these Kawasaki larger well nuts?
Thanks!
Drew
Ft Lauderdale
CCS-FL 424
K636 Race
ZX14 Commute
CoolWhip
CoolWhip's Gravatar
Brewtown Metropolis
RE: Help, need source for well nuts!
10/22/10 8:43 AM
Drew it is: 92015-1692 NUT,RUBBER,6MM
Source Ron Ayers micro fiche HERE. I have also had to replace those a few years ago. Be careful to not over tighten them in the future.
* Last updated by: CoolWhip on 10/22/2010 @ 8:44 AM *
10/22/10 2:11 PM
Had the same problem. Pretty scary pulling it out. Thought it would break off. I leave those almost loose now. They never come out.
lytnin
lytnin's Gravatar
10/22/10 4:10 PM
http://www.murphskits.com/catalog/index.php?cPath=130_136
zx14drew
zx14drew's Gravatar
10/22/10 6:43 PM
Ordered 92015-1692 from online oem source...
Hoping they are the ticket!
Drew
CCS-FL 424
K636 Race
ZX14 Commute
alg8er
alg8er's Gravatar
10/23/10 1:11 AM
answered you on other thread. I had to wrap it once with electrical tape to get the nut to stop spinning so the bolt could grab.
10/24/10 5:31 AM
Click
zx14drew
zx14drew's Gravatar
10/24/10 9:10 AM
Thanks all...
CCS-FL 424
K636 Race
ZX14 Commute
b00fa
b00fa's Gravatar
Cambridge, Ontario
10/28/10 5:02 PM
do a search for desmoparts.com they sell the stuff bulk you can get the well nuts in 4/5/6mm sizes as well as all the plastic washers for 4/5/6mm screws in clear and black nylon
Also I have noticed a descrepancy as well some are saying it is a 6mm well nut you need but I see most places say it is a 5mm I ordered both
* Last updated by: b00fa on 10/28/2010 @ 5:04 PM *
I ride a 2008 ZX14 SE
PCV with Autotune
Vance & Hines slip ons
K&N air filter
Puig double bubble screen
GenMar Risers
Rizoma Grips
Throttle Miester
Engine Ice
Muzzy Fan
Muzzy Frame Sliders
APE Manual Cam Chain Tensioner
Spiegler brake & clutch lines
Carbone Laraine brake pads
Custom black anodized parts
jamesfs912
11/09/10 3:43 PM
ZX14drew were these the correct parts? This seriously just happened to me today on both sides.
zx14drew
zx14drew's Gravatar
11/10/10 7:26 AM
I ordered OEM 6mm well nuts from babbits (other OEM suppliers should work fine) and got exact repacement parts for the tank/airbox well nut. Here is the kicker, the OEM part diagrams show the same part number for this well nut as the more common 5mm well nut, I called babbits and spoke to them to clarify, and the 6mm has a " -xxxx " specific order number that must be specified to differentiate this from the 5mm. Im on the road and dont have the numbers, but just call the OEM supplier and clarify this with them in your order.
I also ordered a few 6mm well nuts from Desmo as cited above, the rubber flange on them is thinner than OEM, but they were a good supplier of bolts, silicon washers etc.
Drew
CCS-FL 424
K636 Race
ZX14 Commute
jessejames4
jessejames4's Gravatar
Fairfield County, Connecticut
08/01/11 11:31 AM
I almost ordered these two well nuts (92015-1692) from Babbits until I saw the shipping charge of $16 DOLLARS!!! Always pays to check.... and this site murphskits.com wants $7+ for each PLUS a lot of shipping $$...
It's an almost $9 order on Desmoparts.com! Did anyone find a reasonable source for these? These thing should cost under a $1. Anyone have a couple of extras new ones they could throw in an envelope for $4 or $5?
* Last updated by: jessejames4 on 8/1/2011 @ 11:32 AM *
Jesse 06 zx14 stolen back in 2019 97 zx11
zxinit
zxinit's Gravatar
08/01/11 12:15 PM
Maybe try your local stealership? I know I am crossing a line here, but sometimes they do get it right, and at a reasonable cost.
08/01/11 1:08 PM
lol Babbits is right up the road from me...worthless stealership IMO.
Anyway, do a search for wellnut on Amazon. Seems like I had some luck last time this topic came up.
08/01/11 1:10 PM
quick search... 6mm wellnut
about 2 bucks a piece
08/01/11 1:26 PM
I had one go bad, my dealer's service manager gave me 2 so I have a spare now.
motorpycho
motorpycho's Gravatar
08/01/11 2:05 PM
Went through this last year. I dont torque them things at all now and have had no problems. Found 6mm at Lowes. They had 5 of them and I cleaned them out. Stealership will charge a couple of bucks and I think they were dollar something at Lowes.
heathun
heathun's Gravatar
08/01/11 3:00 PM
Go lowe's and check the hard to find parts bin. Thats where i get mine they have both sizes and less than $1 each.
08/01/11 4:17 PM
I ordered a couple from the stealer. Took two tries but hey got it right after odering the incorrect small well nut. Just go 1 1/2 turn past the point where you feel the rubber squeeze. Loose. It will never come out until you remove it and it will never split again either..
08/01/11 5:13 PM
thanks for doing the the leg work guys
b00fa
b00fa's Gravatar
Cambridge, Ontario
08/03/11 2:05 AM
do a search for pro-bolt on google, its a company in England they have lots of well nuts and aluminum fasteners that can be used on the ZX14
PCV with Autotune
K&N air filter
GenMar Risers
Rizoma Grips
Throttle Miester
Engine Ice
Muzzy Fan
Muzzy Frame Sliders
08/03/11 8:19 AM
Dealer would be cheaper than shipping and import tax from England to USA. Maybe not so bad for you in Canada?
jessejames4
source for 6mm well nuts found!
08/04/11 11:08 AM
I found the 6mm well nuts over at www.bikebolts.com and ordered them. Guy's name is Steve and two of them shipped were $3.54! I'm sure he's not making a lot money on these so I will be using and recommending his web site to others in the future. Thanks Steve for stepping up, much appreciated!
(Disclaimer: Don't know these guys, never used them before.)
