Thread: anyone have a new tire mounted then have a wheel hop?
Created on: 11/01/13 02:34 PM
speedyme
11/01/13 2:34 PM
I had a new rear tire put on and felt like the it was bouncing up and down, so I put it up on rear stand and the sure enough the tire has a high spot, if this has happened to anyone here was it a defective tire or just mounted wrong? im taking it back to my dealer tomorrow and they said they will replace it if needed,
RE: anyone have a new tire mounted then have a wheel hop?
11/01/13 2:44 PM
"tire has a high spot"...bead look okay?...if so....tire's bad...sheesh...never heard of this before.Any pics?
speedyme
11/01/13 3:02 PM
actually the bead doesn't look even on the rim, one spot is lower than the rest of the tire, that's why I was wondering if maybe it wasn't mounted right I didn't even think that was possible, I ve never seen that happen in my 28 years of riding. I didn't take any pics would really be hard to see anything, thanks
wfozx14
wfozx14's Gravatar
Upstate New York
11/01/13 3:06 PM
I guess your dealer didn't even balance it? Stuff like that burns my ass, give em hell when you get there.
speedyme
11/01/13 3:10 PM
it has wheel weights on the rim and I know they are new becase I had to peel off the goo from the old ones, you would thing he would have noticed it when he balanced it that it wasn't perfectly round, oh well
11/01/13 3:24 PM
I don't think balancing matters a whole lot for motorcycles. I will alaways do it but I have been told it will not make handling any better but improves tire life.
this sounds like a defective tire. Take it back. Free replacement and install....I'd ask for some free oil too. ..or bike polish or something. Tell them you almost crashed.
11/01/13 4:25 PM
Put in 60/70 pounds of pressure. Take the back wheel off the ground, find 6th gear and hammer the throttle. The centrifugal force will pop the bead out. Minor mounting by said novice nimrods.
Towball
Towball's Gravatar
11/01/13 6:13 PM
Balance weights make a massive difference. I tried track racing with a unbalanced tire once and it felts like the final drive bearing had collapsed when going over 100.
If its not on the bead then it can be balanced but not round. When its back on the bead the balance wont be correct afterwards.
To re bead you will need take all the air out and work more of the bead inside the rim than it has already and add some dishwash liquid and water around the bead or tire lub then blow it up again until it pops onto the bead again. Then it will need balanced again. A shot of 50 pounds may pop it on but you really need some lube on the rim to help out.
* Last updated by: Towball on 11/1/2013 @ 6:15 PM *
speedyme
11/01/13 6:20 PM
thanks guys im gonna see what the dealer does first, im sure they will make it right, just no way I can leave it this way
speedyme
11/02/13 10:38 AM
well took it to my dealer today and they said it was a defective tire and replaced with new one and now it rolls perfect, they said they have never seen a tire do that,
carabuser
carabuser's Gravatar
11/02/13 11:26 AM
It happens, just curious, what kind of tire ?
Predator Race Team #14
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
speedyme
11/02/13 12:30 PM
pilot power 2ct
BUSAKILLER1987
BUSAKILLER1987's Gravatar
slidell, louisiana
11/02/13 12:46 PM
wow, that's odd, especially on a michelin
1975 Honda 754 super sport
2001 yamaha yz250F
1975 Honda cb 360
11/02/13 3:04 PM
QC, I said I said, QC out the factory door? I send blems to dealers?
http://www.youtube.com/watch?v=InaRIYFPMiY
Towball
Towball's Gravatar
11/03/13 1:38 AM
Doesn't mater if tire was faulty or not it shouldn't have left a bike shop not on the bead correctly.
Im picking tire wasn't the problem. Install was the problem and bike shop wont admit it.
Did they say they road tested the new tire and gave you the same one back again?
Did you watch the new tire go on the rim 2nd time around?
If you did get a new tire your old one will be on another bike.
speedyme
11/03/13 6:50 AM
Yes i actually seen them take the one off and put new one on then i looked at the old one. To see if i could see anything wrong with it but i couldnt it looked normal. All i care is they made it right and i didnt have to argue or anything. They lifted the bike spun tire and said your right we will put a new one on. Cant ask for better service than that. They are a very reputible dealer
