The secondary fan is on hold now since the OEM fan i bought off eBay wouldn't work. I pop riveted 2 mounting brackets to my radiator ( the top middle bracket is used for both fans), i couldn't weld them on since the radiator is aluminum and i don't really know anything about welding aluminum and my welder isn't set up for it. The bracket that the fan screws to i cut apart and did some swapping around so the fans would be even and not both angled to the right. Now all i need to do is order another fan install it and wire it up to my toggle and battery.
I had to put the baffle back in my exhaust since it was way to loud for street use, ill probably pull it out for drag racing and the Texas Mile.
The Bazzaz is hooked up and im still working on wiring in the datalogger.
While i have it apart i decided to take the rubber boot off the engine.
I fabricated a mount for a toggle switch and gauge. I also forgot to mention i installed a PMR killswitch.
Brock's street meg doesn't come with a o2 sensor bung already welded in, that was pretty disappointing.
I will also be installing heavy duty clutch springs since the clutch was slipping alot last time i was at the drag strip
Stock 08 Special Edition. Brock's Street Meg Ceramic Coated, Bazzaz Z-FI, DL-32 Datalogger, GPR, and some other little things.
