Today as I parked my bike at work, I reached down with the heel of my foot to put the kickstand down. With the stock kickstand you can reach behind the foot peg or just in front. The little stud sticking out just in front of the peg is the most natural and what I typically use. Today my foot must have been out of practice because I accidentally tapped the shifter on my way to swing out the kickstand, the bike went into gear an lurched forward. Luckily it died but I could tell it almost went into gear. Had that happened I for sure would have fallen off/tipped over an who knows what would be damaged on the bike. I was already in neutral so I did not have my hand on the clutch.
Moral of the story is be careful and keep that clutch pulled in until you get the kickstand down.
Rubber side down !
Darkarcher
