What is a reasonably expected amount of miles on a ZX14 from 06-08?
There is at least one guy at Bikeland that had 100K on his 06. He said it was running as good as new. This was last year I read his posts. I have no doubt he is still there with the same bike or he got a new 14r.
How many miles have you put on your bike?
38,000 on my 08.
What parts do I need to focus on inspecting when looking at a bike in general?
Look for scraped oil drain bolt shield or dented headers below. Wheelies that came down HARD and hit. Brake pad wear bars --how much wear left in them. Sprocket--can you see hook shape to teeth...might. If you can see it that is pretty severe. How new do the teeth look on the sprocket. Are any missing? Look for pits on the outermost parts of the fairing, especially lowers and look under exhaust for dent....if you see this, the bike was tipped over. No biggy bur pretty good reason to not go with the offered price. Tires...how much wear before the wear bars are level to the tread? Does the guy have receipts and or pics of the maintenance done on the bike? Is it clean. If its dirty that is a good indication the owner neglected more important stuff.
And on the 14's?
Look at upper engine on the left side. Many leak. Can be fixed without too much trouble but a good bargaining chip if you find a leak. CAm chain will rattle at start up and it will clunk into 1st from N. That is pretty typical. Front brake may squeal at low speed and pushing the bike--typical. Chain past 3rd mark from front = needs replacing soon.
Are there any particular models or years I should be on the look out for?
If you look at an 06-07, make sure it had the frame recall work done to the swing arm. Just a bolt re-torque or if it was one that broke, new frame.
Good luck. I would NOT hesitate to buy a used bike now after owning 2 new ones. These babies are tough. I still would insist on feeling a used bike was properly cared for and I would insist on a low price. If I am going to pay big I'll buy new again.
2024 ZX-14R bran friggin NEW!
