Thread: Lowering peg vs rear set
Created on: 06/01/15 08:13 AM
xravin
06/01/15 8:13 AM
Hello all. Just brought home my new 14 on Saturday, what a machine! I rode for a few hours and I think I'm going to need some more leg room to be comfortable on it. I looked at the Knight Design 1 3/8" lowering pegs, but I know some people were worried about cornering clearance and rear brake adjustability. Is it a better idea to go with a new rear set instead? I don't want to sacrifice any cornering ability. If so, what rear set is recommended?
Blkcasper
Blkcasper's Gravatar
RE: Lowering peg vs rear set
06/01/15 10:55 AM
I've tried a couple of different ones.
Stock, Then went to this setup, 360 degree pegs. Fit in stock peg location and didn't require any mods to brake or
shifter. I wear a size 13 1/2 shoe so worked for me.
Eventually went with a fully adjustable set off ebay as I wanted to change shift pattern to reverse shift and install a quick shifter.
* Last updated by: Blkcasper on 6/1/2015 @ 10:56 AM *
Luvin My ZX14R'S.
06/01/15 10:55 AM
It would be nice if there was a comprehensive test done that focussed on foot peg height range of rearsets. I like Vortex. It seems most adjustable. Satos are on the busa and there are not as many adjustments but the range seems similar. Recently found out about Striker reasets and they seem to adjust higher and farther back so you might check on the lowering capability of those. They seem like very nice rearsets.
If you don't want to sacrifice cornering clearance, Don't go with rearsets. From my measurements, the Vortex rearsets don't improve cornering clearance because the pegs are longer. If you cut them shorter, that would do it but that would be tricky because the bolt goes right through the center. You could try to bevel, the bottom of the tips like the stock footpegs but you may run into the center bolt problem there too.
The stock pegs are really the best for cornering clearance because they have the spring hinge in case you do touch a peg. There was once some plates that attached to the stock footpeg bracket that allowed you to lower the stock pegs. That would be best and also it was not too expensive. I not sure I would mess with the brake pedal height too much. It might not be dangerous if you have a short toe peg sticking out. Get used to lifting your foot up to rear brake.
HanksZX
06/01/15 11:53 AM
Corbin made plates to lower the pegs on the left and the peg with brake cylinder and brake pedal on the right.
I had them on my 07 and now on my 12. The difference in comfort is night and day but they do move the pegs outward as well as down. Cornering clearance is affected but I have gotten used to putting the ball of my foot on the peg when cornering with the feeler dragging and the peg starting to fold and so far have had no problems.
There are trade offs with most things but the increased comfort makes this setup worthwhile.
2012 ZX-14r
nkd
nkd's Gravatar
06/01/15 2:26 PM
I had a bracket laser cut to move the pegs by 20mm lower and 10mm back and added a spacer to the rear shock raising the bike by 30mm. No peg scraping so far.
danfzx14
danfzx14's Gravatar
06/01/15 2:36 PM
While doing some research I ran across these:
http://www.murphskits.com/product_info.php?products_id=401
Supposedly, from what I read at various places online, they will work on a ZX 14. I may give them a try at some point. Just a thought.
* Last updated by: danfzx14 on 6/1/2015 @ 2:38 PM *
AussieZX
AussieZX's Gravatar
Sydney, Australia
06/02/15 2:33 AM
I use these pegs. They have two settings, 25 and 40mm. I have mine set at 25mm. I am 6'5". I have scrapped the outside of my boot during adventurous riding but that is leaning a good way over. I find these, along with adjusting the gear lever and brake lever, the near perfect fit.
http://www.ebay.com.au/sch/sis.html?_kw=LOWER+LOWERING+CNC+ADJUSTABLE+FOOTPEGS+FOOTRESTS+REARSETS+KAWASAKI+%2806-14%29+ZX14R&_id=271366761640
2013 Kawasaki ZX14R in green thanks!! In my part time, I take photographs... www.alluringlightimages.com.au
Scorpion Exhaust
Bar Risers
Double Bubble
Pussy Grips
Kawasaki ZX14R Blaze Green
Kawasaki ZX14R Midnight Saphire Blue
Honda CB500X
EZX
EZX's Gravatar
06/02/15 6:08 AM
I have the Murph's and the first thing to touch down is my foot.
Bradley427
Bradley427's Gravatar
06/02/15 8:15 AM
I have Murphs also, love the pegs! It was weird at first since in order to get the pegs lowered past the hinge mechanism they are out further than the OEMs on the surface where your boot rides. What I mean is your left foot is 3/4" farther to the left, and your right foot is 3/4" farther to the right, and both feet are now 1"+ lower with about double the surface area compared to stock for your shoe to sit on.
I screwed some OEM curb feelers into the Murphs pegs and went out to try and touch em. I can scrape both sides, but the pegs fold just like OEM anyways so no problems there. Much more comfortable to sport-tour on, and I had mine powdercoated flat black to blend into the bike, they look stock.
Sold: 2012 Kawasaki Ninja ZX14R
Next: _________ ????
Blkcasper
06/02/15 9:49 AM
I used theses. Worked great. Fits stock location and also fold n like stock pegs in case of a tip over.
Your text to link here...
I also purchased Cycle Pirates adjustable brake and shift levers.. I like bling and the work get to get the pedal
adjustment exactly where I like it
Luvin My ZX14R'S.
doubleD
doubleD's Gravatar
06/10/15 8:06 PM
Buell XB foot pegs $40 http://www.buellparts.net/content-product_info/product_id-1427/firebolt_xb_footpeg_kit_rider.html
I replaced the long "feeler" screws with shorty's.
BigBloke
BigBloke's Gravatar
06/11/15 1:43 PM
I have the Murphs, and just screwed the stock feelers into them. I have yet to touch anything down. Er, ymmv.
'07 ZX14, Boz Bros slipons, Corbin saddle, Murph's footpegs, Shogun frame protectors, Targa fender eliminator, carbon fiber heel guards
