Pg. 9-45. Bottom right picture.
Free wheeler:
When we are in N, we have to have gears that free wheel or we would be direct drive. We have a brass cage locked around a splined shaft. The free wheelers or the gears that roll free is when the clutch is spinning with engine; They are on the one countershaft gears too. They need to be lube via pressure feed, just like a crankshaft bearing, or splash to the wrist pin. This hole is on top of the rod; so oil enters via splashed drops into that hole that lubes the wrist pin.
How can we drill a hole in a few free wheelers and not create a stress crack that might compromise a gear. We are stuck coasting in N with engine on. We need to feed that bearing or a galling effect will happen. The oil cannot enter as that flat [the rear gear in the photo] begins to heat up, expand, touch metal to metal; scores the softer material with the harder one. Off she goes snowballing that galling effect in a fast circular motion. Now the gear is all wobbly and not tight on the cage.
Roller needle bearings:
We have the [front gear in the photo] with the needle bearings. The shaft now, stops being a spline. Now it is looking like the back gear's I/D is the shaft's O/D for the rollers now spin on that shaft area. The rollers needing lube is again, a needle cage needing lube. With the excess room in the cage, the extra oil rolling over the others, it takes a little longer to take out a roller type bearing. None the less, this needs idle lubing on the coasting just as well.
Between splash, transmission pressure via engine running, bring that clown forward who said splash and lube will hurt miles of coasting, we have both covered lube wise. I would think there is less stress on the trans. So wear is the damage coming from? I coast down canyons more than I wanna say. Show me the 14's problem I keep the engine on, knowing that trans on the 'freewheeling side' needs it there.
Will coasting a mile without lube cause a problem? I can't say for sure. If I 1/4 mile a few seconds of idle within 4 times to lube [the wheelers] within that distance?; I may have a better chance at the starter button every now and then, than just flat out let the gall do its thing and worry miles down the road later.
