That is the question.
Taking advantage of the weather this weekend to swap my slip-ons. Always put them on and tightened them down and never had any leaks but have been reading that a small bead of high temp sealant should be used regardless.
What say all of you? Should I just put them on without and see if a leak is present or put some on regardless.
If so, which sealer to use?
Thanks!
