I just got some Dunlop Qualifiers. $280 for the set, free delivery. I got a 120/70 for the front and 200/50 for the rear tire. I have a theory that the sides of the 200 will get pulled in slightly being mounted on a 6" rim. They're recommended to have a 6.25" rim.
That might pull in the cap profile a little to make it more vertical at the outer edge. What do you think?
Here's one for you Heathen...
* Last updated by: Sharkey on 11/10/2009 @ 6:18 PM *
Removed GPS.
