I only have 260 miles on the R and I always clean it up after a ride with spray cleaner /polish.
Put it away on Thursday evening and cleaned it as usual. Noticed no marks on the fender or anywhere else either, for that matter. Then we got a few inches of snow and I haven't ridden since.
Today as I came through the garage I noticed that some snow melt splash had splattered onto the front wheel by the garage door. But, when I cleaned the dried splash off I discovered a hairline crack in the center of the front fender. It starts at the front tip and extends a couple inches up the center of the fender. It is invisible until you put pressure on the fender and then it separates.
I will take it to the dealer tomorrow and ask them to consult Kawasaki about the issue. If Kawi will replace fender, I will probably do that; but after I let the dealer inspect and document the crack, I will use some Welder glue to fix it from the underside. That may be all it will take to be a permanent fix.
I gotta wonder if anyone else on this list with a new R has had a similar issue? Especially if you ride in freezing or near freezing temps, I'd like to hear from you. There is absolutely no sign of any impact to cause this crack and you would never see it unless you put manual pressure on the fender and caused the split to open. Left untreated, I would expect it to grow vertically up the fender; neatly bisecting the fender lengthwise as continued riding forces would stress it, especially at higher speeds.
Thanks for any input in advance.
* Last updated by: PaulAB on 3/4/2012 @ 2:18 PM *
