Thread: 2015 ZX14R tire size
Created on: 11/02/15 12:11 PM
brazeagle
11/02/15 12:11 PM
Hello there,
What is the largest tire size I can go without modifications and PROBLEMS on a 2015 ZX14R>?
Thanks
LCL
teef
teef's Gravatar
Brisbane Queensland Australia
RE: 2015 ZX14R tire size
11/02/15 4:04 PM
I don't think too many people would have tried this.
Why do you want to do it? Purely for looks I hope. It will actually degrade the motorcycle's performance.
There is a lot more to it than just width, there is shape and profile etc. By putting a wider tyre on you will not increase the surface area of contact with the road. You will likely just make it harder and more dangerous to corner the bike. Thus why nobody ever does it.
ZX-14R
Triumph Tiger 1050
CBR1100XX
Volfy
11/03/15 12:53 PM
I'm guessing 200/55, for a direct swap on a stock bike. Probably won't change handling too much either. Might even quicken turn in because of the taller tire height compared to 190/50.
* Last updated by: Volfy on 11/3/2015 @ 12:54 PM *
toledoUPSguy
toledoUPSguy's Gravatar
11/03/15 2:37 PM
again a very good question has been asked, why do you want to go bigger?
11/03/15 3:04 PM
Measure from your current tire to the closest solid component, whether it be the chain or swingarm, multiply by two, add the number to the first number of your current tire, and that is how much wider a tire you can fit.
maverick1441
maverick1441's Gravatar
11/03/15 3:52 PM
As stated above a 200 will not increase your contact patch and will only translate into a taller tire. Increasing your rim width is the only route to a wider tire. Fitting a narrower tire on the rear will stretch the tire out and actually produce a wider and "square" profile. Shinko's hook-up drag radial has a very square profile if that's what your after.
11/03/15 7:20 PM
Seriously, Mav...
zx14rider345
zx14rider345's Gravatar
11/05/15 3:03 PM
Heres the 200/50-17 I had mounted
Heres the 200/55-17
The 55 is definitley taller.
2012 ZX14R, 2016 BMW S1000XR
brazeagle
11/06/15 5:31 PM
GREAT ANSWERS AND QUESTIONS!
The answer for my question is LOOKS and nothing else. I see the 200/55 actually looks pretty good.
Thanks for the picture and all the insights.
WHAT BRAND TIRE is the 200/55 you have?
Thanks again.
Stay safe
LCL
zx14rider345
11/06/15 9:10 PM
Metzeler M7rr
brazeagle
11/07/15 8:15 AM
Thanks a lot.
RIDE SAFE
LCL
Blown3UR
12/21/15 1:52 AM
zx14rider345; I'm curious as to how the 200/55 handle on the 14.. Could you please share your thoughts on this compared to other tire sizes you've had stock included please
Blkcasper
Blkcasper's Gravatar
12/21/15 11:11 AM
Blown3UR if your doing track days it will give you more side tread area when leaned over, and faster turn in and help with side to side transitions, Used this size tire on my 06 zx10 track bike. but less contact patch in the center. It will also raise the rear of the bike about an 1/2 to 1 inch so reset up of suspension is a must in my opinion. If you have a rear hugger installed it will rub on it.
Now for daily street riding will work the same but you will wear out the center of the tire way faster than the
standard tire profile 195/50 or 195/55.
Luvin My ZX14R'S.
darkarcher
darkarcher's Gravatar
Cincinnati, Ohio USA
01/11/16 8:45 AM
My thought here would be that you should go with the 200/50 over the 55. Speaking from a safety standpoint, the tire will already be taller since your cramming it on a rim that is narrower than intended, so going to a taller profile may be an issue. I think the moto gp tires are a 60 profile, but we all know that turn in needs as much help as it can get at 200mph. For street use I personally would only consider the 200/50.
2020 on the way!!!!!!
