The problem is we don't know what the noise is..
Tick: That's after the lash has been checked. So you save parts and never start it again. You'll go from memory for this one. Lash tick is intermittent. Piston skirt tick is the slap of the piston changing direction from TDC to BDC.
The aluminum off the skirt rolls off that aluminum like snowballs being rolled up. So molten hot it leaves a line in the cylinder wall. Lose material you lose clearance and that tick is piston slap [when changing direction].
Knock: This is where the big end of the connecting rod uses inserts, not a roller bearing like the old Z1 cranks. That layer of aluminum bonded to the brass layer has that kind of old 450 clearance or less and if that is snowballed off, this creates a tick swing before a knock. That tick is the piston crown or the squish band area from head to piston... hits the head and ticks if you can hear it, but probably too late at that point.
Rattle: The access to the slipper is the right crank cover removed and with a pair of needle nose pliers, you move the slipper up and down to see if it holds in place or moves too much, is broken off, etc.
_____________________________________________________________________________________________________________
Oil Filter: This is the quick and dirty, quit fucking around; tear it open and look for aluminum and brass insert material. Clean? Then start the bike, it's not the bottom end.
Oil Pan: This is the longer way around by pulling pipe, dropping pan and inspect. That's two choices of 'why fuck around', when you can clean the pan of gray matter material from the clutch pack and make the engine last that much longer without contamination build. Call the pan the gravity filter needing attention. You then can peek and push the big ends and see if the caps are blued from heat anshit.
