From the SM. You should get one of these.
Throttle Control System Inspection
•Check the throttle grip free play [A].
Throttle Grip Free Play Standard: 2 ? 3 mm (0.08 ? 0.12 in.)
*If the free play is incorrect, adjust the throttle cables.
Check that the throttle grip [B] moves smoothly from full open to close, and the throttle closes quickly and com- pletely by the return spring in all steering positions.
*If the throttle grip does not return properly, check the throt-
tle cables routing, grip free play, and cable damage. Then •lubricate the throttle cable.
Run the engine at the idle speed, and turn the handlebar all the way to the right and left to ensure that the idle speed does not change. If the idle speed increases, check the throttle cable free play and the cable routing.
If necessary, adjust the throttle cable as follows. •Loosen the locknuts [A] [B]. •Screw both throttle cable adjusters [C] [D] to give the
throttle grip plenty of play. •Turn the decelerator cable adjuster [C] until 2 ? 3 mm •(0.08 ? 0.12 in.) of throttle grip play is obtained.
Tighten the locknut [A]. •Turn the accelerator cable adjuster [D] until 2 ? 3 mm •(0.08 ? 0.12 in.) of throttle grip play is obtained.
Tighten the locknut [B]. If the free play cannot be adjusted with the adjusters, re- place the cable.
* Last updated by: Rook on 7/10/2013 @ 5:58 PM *
2024 ZX-14R bran friggin NEW!
