Homework assignment.
Q. I want to know if engine parts fit my bike. How can I find out?
A. Look up the gasket for the part or cover. If the gasket is the same part number since first gen, then same cover will fit 2nd gen if both gaskets use the same part number, then the gasket o-ring curves with the part, or the paper/metal gasket has the same hole pattern then the cover is the same too.
Q. What happens if they have the same part number for the gasket but the cover has a different part number.
A. This might be a paint color difference as in a charcoal vs. flat black and that might mean two changes in color code numbers but it's cast as the same part.
