1. Close the ram hole with a cork. Cheers!
2. Close the valve cover vents with the slickickass lookey WOT high got!
3. Pull all the hoses off the air-switch.
4. Wrap the PAIR switch in glad cling wrap so it tacks closed.
5. Note: Gas/oil/heat won't be bothered with that plastic microwave me too it's not that hot there [because].
6. Ziz-tie the unit off [whatever] is safe and out of the way of things hot and/or moving. No code here guy!
7. Zip bag the hoses w/intakes.
8. Write down what those hose is are for what?
9. Where did these hose say, I got an idea.
10. Say, you guys got a map for my hose bag? Runs like fill in the blank. All black soot tea looking.
Pro:
I got nut inn for ya. Head back to camp.
Con:
I gots me some carbon buildup in my other ports is ports are clogged and slowing over the new carbon ports is ports are clogged like the other side.
I was all lean machine but now I am on the net more than riding say... Shathe fucup! It's my bike, my map, my my my MY! "Can'touch dish!"
Yes you can.
No you cant.
Yes YOU CAN!
