My 2012 came with stock gearing which is 17/42. When I finished farkles including the BST wheels I decided to try
17/44 gearing. Big mistake at least for me. 1st gear was unusable at full throttle. 2nd gear the bike spent all the time with the front wheel 3 ft. off the ground and that was full power ktric 1. I believe the bike would stand straight up if ktric was turned off. I changed the rear sprocket to a 41 and it is much more manageable. Still will pull the front wheel in 2nd but much more manageable to ride. For the drag strip I think a 40 rear sprocket with the stock wheel base will work out. I have not had the bike on a dyno yet but I expect somewhere around 205.
