Thread: What effect would
Created on: 06/18/09 09:57 AM
JDC
JDC's Gravatar
What effect would
06/18/09 9:57 AM
For a 7 PSI turbo'd bike, ATP, Harry said that stock timing is ok for his kit at stage 1... mine is setup stage 1.
I have the timing -6.
Do you think changing to OEM timing would make a significant/noticably tellable difference in performance?
RE: What effect would
06/19/09 5:13 PM
Seat of the pants unless you have a dyno. Try stock first then back off on the minus if it wants less advance.
BadinBlack
BadinBlack's Gravatar
06/19/09 9:19 PM
The guy that built my kit said stock timing was fine at 8psi as long as I wasn't land speed racing, and I used premium gas. You'll most likely feel a big gain in performance...especially off boost, by adding that -6 degree's of advance back in. From my research I wouldn't think twice about running stock timing at 7psi. Listen to Harry
JDC
JDC's Gravatar
06/20/09 1:30 AM
my schizophrenic mind torn in two. I think next time I'm on that side of the bike I will play with it a bit.
* Last updated by: JDC on 6/20/2009 @ 1:31 AM *
