Thread: Newbie Temperature Question
Created on: 09/19/15 04:48 AM
teef
teef's Gravatar
Brisbane Queensland Australia
09/19/15 4:48 AM
Hey Everyone,
Not a big deal, this is more just because I am new to the bike. It's a brand new ZX-14R just run in now. I'm just wondering what the normal range of temperatures is when riding?
The reason for asking is that I am comfortable with the upper end of the scale, it seems the fan cuts in at about 95ºC with the temp rarely exceeding 97º at least while the weather is still cool. The fan seems to pull it nicely back down to around 92º
My question is about the other end of the spectrum. On the motorway this evening, the dash told me the air temperature was 17º and at 100kph the engine running temperature dropped down to 69º
Is this a little too cool? I know too cool can be as bad as too hot.
Thanks in advance.
ZX-14R
Triumph Tiger 1050
CBR1100XX
untamed
untamed's Gravatar
RE: Newbie Temperature Question
09/19/15 6:15 AM
That's normal for me to, in winter I get down to 64/65 deg Celsius running temp if it's around 0-5 deg Celsius outside. In summer it will average around 75-83 deg normal riding in 25 deg + outside temp, but standing at an intersection she will go up to 95-97 but as soon as I pull off it drops down again.
* Last updated by: untamed on 9/19/2015 @ 6:20 AM *
pegscraper
09/19/15 5:08 PM
High 60's is what I see at the speeds and ambient temps you state. In winter with air temps below 10 deg C it'll run low 60's. At a standstill the temp climbs rapidly to 95 deg+ when the fan cuts in. The twin fans pull the temps down pretty quick unless you're sat in the garage with the engine running when it takes a while to get down to sub 90 deg when the fans cut out. Anywhere in the 60 deg + range is hot enough IMO. don't forget the temp gauge shows coolant temp. The oil temp will be higher.
* Last updated by: pegscraper on 9/19/2015 @ 5:09 PM *
teef
teef's Gravatar
09/19/15 10:41 PM
Cool, good to know it's all normal. It runs a lot cooler on average than my Blackbird used to, but then again it's an evolution in motorcycling, not surprising the cooling has improved as well.
Cheers for the reassurance.
ZX-14R
Triumph Tiger 1050
CBR1100XX
Fazed
Fazed's Gravatar
Perth, Australia
10/10/15 6:53 AM
In winter mine runs at 65. That just happens to be the thermostat opening temperature. When riding at speed even in hot weather it remains quite cool. The temperature only goes up when in stop start traffic and usually cycles between 90 and 95. On a 42 degree day it got up to 102 but easily cooled down once moving. What ever you do, never use a Cox radiator guard. It blocks the radiator too much and even on a 20 degree day the cooling fans will struggle to bring down the temp.
* Last updated by: Fazed on 10/10/2015 @ 6:54 AM *
AussieZX
AussieZX's Gravatar
Sydney, Australia
10/11/15 2:29 AM
Sounds normal from my 9 months experience on the bike in Aussie conditions!
2013 Kawasaki ZX14R in green thanks!! In my part time, I take photographs... www.alluringlightimages.com.au
Scorpion Exhaust
Bar Risers
Double Bubble
Pussy Grips
Kawasaki ZX14R Blaze Green
Kawasaki ZX14R Midnight Saphire Blue
Honda CB500X
bfg9000
bfg9000's Gravatar
Cebu City, Philippines
10/11/15 4:09 AM
I live in the tropics (the Philippines, to be exact) and even in the summer, the temp doesn't get too hot (rarely goes over 97ish). Even with a Cox radiator guard attached.
Up in the mountain roads of Luzon (elevation from 5000 to 7500 feet) with temps around 15C, bike stays around 65 - 75C, in my experience.
2013 Metallic Midnight Sapphire Blue ZX-14R + Brocks Alien Head 2 Full System | Spiegler Stainless Steel Braided Brake+Clutch Lines | ZG DB Windscreen | TBR JuiceBox Pro | Arashi Rearsets | BMC Street Air Filter | DME High Pressure Oil Relief Valve | Muzzys Oil Pump Cover | APE Flat Oil Drain Plug | FLO Reusable Oil Filter | Cox Racing Radiator Guard | GPR V4 Steering Stabilizer | CREE XHP-50 LED Headlights | LED Turn Signal Lights | Smoked LED Taillight | Targa Fender Eliminator | Tapemaster Strobed Reflective Rim Stripes | Ballistic Performance EVO3 Lithium-Ion Battery | Pirelli Diablo Rosso III tires
teef
teef's Gravatar
10/12/15 3:42 PM
Had to show my flatmate the way through peak hour traffic yesterday afternoon so she could drop my car off for service then bring her back home.
Temp sat between 95º and 97º most of the time, with the fan doing about 50% duty cycle. It sure knocks the voltage around when it comes on. It idles on about 14.2V with the fan off and goes down to 13.5V with the fan on at idle.
Not much of a way to treat a ZX-14R I know :-(
It had its first ever roll on to 9K RPM on the way home though, that was fun ...
ZX-14R
Triumph Tiger 1050
CBR1100XX
rod442
rod442's Gravatar
10/13/15 3:53 PM
Its getting cold around here (Michigan) today - (50f).
on my commute I was running 143-147f at 75mph on the freeway. That's like what? 61c?
yeah, they run cool at speed.
teef
teef's Gravatar
10/14/15 4:56 PM
Yup, 62 - 64 ..... coming into summer it, I think it will be a while before I see those numbers again once she's warmed up. On a decent day here, she's at 53 by the time I get my gloves on and start riding ;-)
ZX-14R
Triumph Tiger 1050
CBR1100XX
