Thread: Advice on rear shock
Created on: 03/18/13 01:14 PM
03/18/13 1:14 PM
Hello gang. So, I have a shock with a Race Tech heavy spring on it and my latest rear tire is cupping pretty bad on the sides. A fella on a ride we took said that I needed to back off my compression damping. I ride fast 2-up pretty aggressive, and I am hoping to get this tire to last a bit. So, any suspension gurus have any advice?
Thanks
RE: Advice on rear shock
03/18/13 4:24 PM
Back off the preload, too. Your damping is not controlling the spring at this point, if the tire is cupping. Just upping the compression damping might not be enough by itself. You may also want to increase the rebound damping as much as the compression.
Neilp
Neilp's Gravatar
Brisbane, Australia
03/18/13 11:23 PM
Set your sag to the required re your weight, front and back!
Neil
