Thread: close to 5k miles
Created on: 12/06/13 11:58 PM
alohaalex
alohaalex's Gravatar
close to 5k miles
12/06/13 11:58 PM
Guys i cant find my manual and i'm getting close to 5k miles, is there any service to do at this mileages more than oil change or the one at 7500 miles is the important one? if it is just an oil change i can do it myself but if it is something else i will need to schedule a service maitanace with the dealer. please let me know.
none
Blkcasper
Blkcasper's Gravatar
RE: close to 5k miles
12/07/13 12:36 AM
You should be good at 5k with an oil change. The 7.5k is the big one. Recommend air filter, spark plugs, oil change,clutch adjustment, ect. I would suggest replacing the acorn bolts on the frame neck that bolt the spedo on. Or at lest removing them and adding loctite. Mine came loose as have a quie a few others.
Luvin My ZX14R'S.
alohaalex
12/07/13 12:47 AM
Cool I will do the oil change and take the bike to the dealer at 7500, but you got me worry about the bolts, do you have a picture or can you take one of the location of these loose bolts? Thank you sir!
none
12/07/13 12:50 AM
The bolts are the attach point between the steering tube and the meter...that bracket(black).Two bolts.Can't miss em.An upper and a lower.Large...probably 10-12 mm size.
* Last updated by: Grn14 on 12/7/2013 @ 12:52 AM *
alohaalex
12/07/13 12:54 AM
I will check them tomorrow, thank you guys!
none
12/07/13 1:52 PM
There's a thread somewhere on here that has more info, PM Rook he's the man!
12/09/13 5:06 AM
1000 - 6000 and 10000 is how I roll.
At 6000 I put semi synthetic, at 10000 I put full synthetic. PADOW. If you attack things on the bike before the service interval it will assist in engine life. If you attack service intervals after you hurt the bike (potentially). Those are my 0.02!!!
