Thread: Question
Created on: 03/14/15 08:24 AM
KINGY2
KINGY2's Gravatar
ST.JOHN'S NEWFOUNDLAND
Question
03/14/15 8:24 AM
When putting chain wax on, with bike on center stand and in neutral, i noticed the rear time turns slowly.
I can put my hand on it and it stops with no resistance, does my clutch need adjustment or is this normal ?
Thanks.
pegscraper
RE: Question
03/14/15 9:02 AM
I take it you mean when the engine is running? When engine is cold this is normal due to excess crutch drag with cold oil. With a hot engine it should be virtually zero.
RE: Question
03/14/15 9:58 AM
"When putting chain wax on, with bike on center stand and in neutral, i noticed the rear time turns slowly.
I can put my hand on it and it stops with no resistance, does my clutch need adjustment or is this normal ?"...Peg's correct.
Also...to clarify for you...there is NO clutch adjustment for this Hydraulic system.Anyone(shop or whatever)tells you you need a clutch adjustment is straight out wrong.Just so ya know.
* Last updated by: Grn14 on 3/14/2015 @ 9:59 AM *
jimmymac
jimmymac's Gravatar
K.C. MO Northland
RE: Question
03/14/15 11:49 AM
Pegscraper is 100% correct.
I never run my bikes when I lube the chain. I just roll it by hand.
Let's roll
RE: Question
03/14/15 4:05 PM
+1. Normal. You might even feel the bike creep a little with clutch pulled when it is cold and you put it in first gear. The clutch plates don't separate completely because the oil is thick.
+100. Why chance it? If you haven't seen the pics, just google fingers cut off in motorcycle chain. Ugh! I've pinched my finger a couple times just rolling by hand. It's all engine off, cleaning and lubing.
* Last updated by: Rook on 3/14/2015 @ 4:08 PM *
Rktsled
Rktsled's Gravatar
RE: Question
03/14/15 4:22 PM
Rook, I'm with you 100% on this one, have two friends missing the tips of their fingers from running bikes on stands while lubing chains!!! Might seem like a good idea, but it isn't!!!
Rktsled
carabuser
carabuser's Gravatar
RE: Question
03/14/15 6:21 PM
I only run it on the stand after I clean it to warm up the chain, then I shut it off
lube it by hand, heard of the missing fingers too many time is my life ...
Predator Race Team #14
Hayabusa
1980 GS 1100
1978 GS 550
1968 CL 350
1972 TS 90
Winston Churchill
extrapolator
extrapolator's Gravatar
RE: Question
03/14/15 11:57 PM
They're not missing. They know where they are. They're just not attached anymore.
Like when you lose your job. You didn't really lose your job. You still know where it is. You're just not welcome there anymore.
* Last updated by: extrapolator on 3/14/2015 @ 11:59 PM *
=x+rap01a+0r
RE: Question
03/15/15 12:07 AM
You're funny tonight, extrap!
extrapolator
RE: Question
03/15/15 12:12 AM
I've been um consuming img]/images/emoticons/lildeerunck.gif[/img]
=x+rap01a+0r
Jetfixr320
RE: Question
03/15/15 6:34 AM
Someone posted some pics on the Garage Journal of a guys hand from lubing a chain with the bike in gear and running. Some nasty stuff and he wont be riding again.
RE: Question
03/15/15 8:06 AM
...stay away from your chain!
Bummer. I'd rather quit riding because I crashed and broke a leg. I'll pass on unnecessary risks.
* Last updated by: Rook on 3/15/2015 @ 8:08 AM *
KINGY2
KINGY2's Gravatar
RE: Question
03/16/15 8:58 AM
Thanks guys that is good to know !
GRN nice to know that the clutch never needs adusting, my old VF1000 had a hydraulic clutch.
Just to clarify i did the chain wax by hand with engine not running, after i started it for a minute and noticed the rear wheel slowly moving.
Blizzad here today vehicles are totally gone under snow banks.
RE: Question
03/16/15 9:14 AM
Y/W
RE: Question
03/16/15 10:03 AM
I lost my house. Well, I didn't lose it. It's just that there are other people living in it now.
extrapolator
RE: Question
03/16/15 9:12 PM
=x+rap01a+0r
RE: Question
03/16/15 11:23 PM
RE: Question
03/17/15 5:48 PM
Holy shit? Someone's running their bike on a stand to lube the chain? You've got to be fucking kidding me.
Hope collecting $2k worth of life insurance when you get your goddamn fingers chopped of is worth it.
RE: Question
03/17/15 7:45 PM
No, he's cool. BTW, mine always does that when I start it on the rear stand. My busa does the same.
KINGY2
KINGY2's Gravatar
RE: Question
03/18/15 8:19 AM
No Vic i am not that phuckin stupid.
RE: Question
03/18/15 9:35 AM
King, that's what you want to see is a nice loose drive-train. When in N, the main-shaft is always spinning with the clutch. The gears in N are called 'freewheelers.' They are engaged when you shift up or down. The freewheelers slide fore or aft. The counter shaft sprocket is sort of locked with the rear wheel, correct?
There are now fixed gears on the counter-shaft. With the engine running, the oil in between the freewheeelers of the main-shaft, this drag is causing momentum on the freewheeler to start building speed as the oil sort of drags the gear with it. This now moves the fixed gear on the counter-shaft, moves the output bearing and that rubber seal is dragging that momentum down.
Every link is now a drag and that oil is still pulling those freewheelers to move bearing after bearing, link after link, rubber seal after rubber seal in the rear wheel alone... That makes one think... No kinked links, no bearing gall, just a loose as a goose tight as a drum drag wink-wink... Like the way my parts act?
Vic, did you plop a senior citizen *forehead pop* on the 'comprehension reading?' I had one of those yesterday on faceplantbook. After he hand turned the wheel to lube the chain, then he lit the bike off, saw how beautiful the parts moved while running. Then he asked the question about how much throttle it takes to pop the pinky off as opposed to the index finger speed?
* Last updated by: Hub on 3/18/2015 @ 9:36 AM *
KINGY2
KINGY2's Gravatar
RE: Question
03/18/15 11:03 AM
Thanks for the info Hub !!
