OK. I know this has been discussed but please give me your opinions based on experience.
I'm going to sell the 14 soon. Doctor says I can start doing things like working on a bike in a couple more weeks.
It apparently started leaking a few months ago. Right now I haven't even wiped the leak down. I start the bike every 5 days or so for about 6-7 minutes. During that time it usually leaks a single drop on the ground. I will tell the buyer about the leak but I worry the leak could be a deal breaker. I think the leak would slow down a LOT if the bike was ridden regularly. I saw nothing that would drip on the ground during my Death Valley trip. So sitting in the garage stone cold allows the surfaces to contract and leak more when you warm it up. But you could imagine the buyer might think the leak is worse than I say.
I don't really want to replace the gasket unless I have to. I'll have the fairings off anyway to replace them.
Is that rubber heat shield hard to get off? Can I remove whatever is necessary with just basic tools?
Have any of you simply re-torqued the cover bolts to stop a leak? If that doesn't work, I read before that I can get 6 "M10" washers and that might work? I'd change one bolt at a time and re-torque to factory spec's?
If all that fails I'll have to replace the gasket but is that Kawasaki sealant (around $60) really necessary? It's only used on those rubber half-moons I believe?
Any experience appreciated.
