Few months ago the 14 sounded like it was starting to have a miss in it and at idle was not hitting on all 4. It also smelled like oil burning and found oil on the header plus the outside of the cylinder block all glossy from an oil leak. I ordered a valve cover gasket, six bolts, sealing washers for the bolts and plug hole gaskets. I let it sit on the lift and rode my other bikes the rest of the summer then decided to start on it this past Tuesday. All the plugs were fouled out so I put in a set of used plugs for my ZRX just to see what it would do and miss disappeared sounding good. The old plugs were original from factory from 2008. I took the throttle bodies out which I thought would make it easier to get the valve cover off which it did but that was the start of my problems. Valve cover jumps right out with all the extra room so I thought wow that was easy. Problems started Wednesday trying to get the throttle bodies back in. While all attempts failed the wife came home from work and came out to see what I was doing. I explained the problems I was having so she studied it for awhile then asked why the gas tube was on top when the gas line is laying on top of the engine. OK that problem solved so out comes the throttle bodies to turn around and start to slide them in the right way just to get interrupted again by her. She reminded me that they looked good sitting in the intakes but how was I gonna get the injectors plugged in and how I planned to get the gas line on. OK again and back out they come to plug in injectors and gas line on. Before I slid the TB back in she zip tied hanging wires to the throttle bodies and pulled the extra wiring out the right side as I slid them back in then she asked about the clamps still sitting on the lift so back out they come then clamps put in place and TB back in. Finally clamped in properly along with the stacks so life is getting better or so I thought. I started plugging in the wiring connection and ended up having 2 connectors that I could not find the others connectors that plugged into them. She grabbed the flashlight and a pick then dug one out that had stuck on the topside of the throttle bodies and them 2 plugged together. Now I only have 1 connector left and nothing to plug into it. She picked up a wire loom off the workbench and asked what it was for and as it turned out it was for the coils which after I connected them it completed the wire loom. Turned key on and it was dead. She shakes her head and asked if I remember what I told her when she 1st started riding what to look for when that happens. She flipped the kill switch off and the bike fired right up and sounded good.
She just looked at me and said cut 4 times and measure one then walked away. I still am not sure what she meant but it is running and sounding good. Only 1 more problem and I cannot find any of the plastic for the bike. It looks like a plucked bird with all of it gone so today I am going to look in my truck that does not run to see iffens I stored the plastic in the cab along with all the screws that holds them on.
