Can anyone tell me how I could know if a balancer was out of adjustment?I was reading about HOW to adjust...but it said nothing about "symptoms".Thanks all.
Created on: 07/22/10 12:48 AM
heathun
RE: Balancers
07/22/10 6:56 AM
blue heres a thread on it maybe it will help
RE: Balancers
07/22/10 7:15 AM
hey blue just go this route
RE: Balancers
07/22/10 8:46 AM
Ya Scotty...just awesome..."engine removal necessary for installation"...or some such nice simple mod. Think I'd FIRST go with a "re-adjustment" by the book.Not even sayin it needs it...hell,IDK.She feels fine.Nothing weird or different.Just you know,as we add up the miles,some things start happening that are so subtle we may not even realize it's occuring UNTIL we "redo" some things.I "think" she feels the same as when I first got er...but that's been 3 years ago,and several different configurations as far as drive train and engine use go.Ah,most likely leave er be.Maybe sometime up ahead.Thanks for the links though.The Shnitz route is DEFINITELY a NOT!
* Last updated by: blue07 on 7/22/2010 @ 8:54 AM *
heathun
RE: Balancers
07/22/10 8:51 AM
Blue, it only takes a few minutes and it's simple. If you use a long flat head and have a long opened end wrench you can do it without removing any body work. Adjusting them just to make sure won't hurt anything, just make sure he's warmed up and idle down to warm idle.
heathun
RE: Balancers
07/22/10 8:59 AM
It's a simple straight forward job just follow the manual and adjust them in the order it states. I think it says to adjust the front first but double check. Don't loosen the locking nut too loose just enough to be able turn the adjuster so it doesn't move while your locking it back down.
RE: Balancers
07/22/10 11:11 AM
Are we thinking this is a cam chain/drive chain adjust my balancers? Needle bearing wear is knock-knock if there is no noise, it's like saying, I'm going to remove the cams and realign them as if that is one big roller sitting in a bearing and where is it going to go?
Like pulling the wheel bearing out, and now reinstall it, she is good to go. Eccentric is the gear up against a gear my line bore. Once it is set, it is set. Don't bring up some off the wall it went away is one bike or two with a knock noise.
How can you compensate for a rubber cush-drive where you would feel a bump on lift and drive is a cush drive knock. You knock out the parts and change them, not set a gear up tighter up against another gear is the whine on the eccentric jamming that gear into the crank's gear.
Needle bearing needlessly waste your time go ahead, ain't my bike is more a logical look at that needle bearing and where is that going to go; think wheel bearing but gets worse with or without a whinear.
Slowninja
RE: Balancers
07/24/10 9:46 PM
Whatever you do, DON'T remove the balancers. I'm certain if it weren't for that my bike would still be entirely streetable. But now, it vibrates so bad I refuse to ride it on the street. Don't do it!
billeason
Slowninja
billeason
kawnow
