If you could find a flat piece of glass, not plastic, started the bike cold so you don't burn yourself with the hotter oil, you are simply going to remove the filler cap, cover the hole with the glass plate, start the bike and watch the basket if you can?
The basket has to wobble that severe, but you have a smooth running bike, right? Being that is sort of a mess and might break the glass pushing down at the hole. Try the trick I was after. I'm riding with the pulse at a sustained speed. I then slowly pull the clutch lever in so it still is engaged, but about to disengage. At that range after you find the lever's liquid gap, then the pressure begins, there is where you begin the load and pull the lever slow.
So if it still pulses at the whole range or throw = Warranty! Something is not right. I have zip for a pulse and my fingers always for the most part, rest on the levers. So for me not to notice a blip at the knuckles, my guess is it is not normal.
* Last updated by: Hub on 7/12/2013 @ 1:34 PM *
