It's that reversengineering in me. Blame Ivan... LOL... So this scenario goes something like this:
Center switch: More like a safety. Look around, click all you want. I clicked on it when in center mode. It did nothing. Without being in right click, you are just looking around in center mode.
Right switch: In this mode, you can writer/save/burn. You are here and will make map after map and just save as you go. I do not need to leave right toggle once I saved my first map. I am going to make 10 maps now all in right toggle mode. I am not going to burn any, I created many map modes to try. I am going to call it a night, put my 10 saved maps in the center toggle. Why? So the next move is for the ECU to accept one of 10 saved maps 'is one operation.'
Next morning, I am going to burn the first flash in right toggle is pull my first map. Or??? Where did they go?
No, moving to center then back to right (flashing mode) resets the ECU so it is ready to accept another read/write operation
Wait a minute. If you are saying this, I made 10 maps and never moved out of right toggle. Because you said,
It does not clear what you have saved or change what has already been written to the ECU
Understood. We are not talking about what is written in the ECU.
What I'm trying to figure out is what do you mean as an "operation" to be accepted? I understand the save/save as part once you make a full map, pull up all that is to be pulled up or clicked off. I now saved that one map changing the igniting map, the fuel map, and the limiter radio click. I have 9 to go. Are we saying, go back to center, that is one operation? Now, to make your second map, move back to right toggle. Because your first operation or the maps you brought up were saved, but that is one move. You now move the toggle to center once you hit a save. This then saves it to the hard drive.
Now, go back to right toggle and make your second map. Pulling up all your maps and radio clicks, those moves have to be saved. So save that map. That save has to meet the center toggle. Now, go back to right toggle and make your third map.
No, do not make 10 maps and save without moving to center to save that map made or call it an operation. How close are we now?
Left Toggle: As far as its use for the 14, are we saying this mode is not used for anything? We build the same unit with the 3 way toggle for other bikes, correct?
* Last updated by: Hub on 8/27/2013 @ 8:51 AM *
