Whenever I read guys are going with Nos on a flashed ECU It's all I can do to stay out of the convo.
I pretty much always tell people that they will need to tune after a flash just because of what has been discussed over the past few pages of this thread. IF THE FLASH WAS CREATED ON BIKE A, IT MIGHT STILL BE WAY OFF FOR BIKE B. Closer to perfect but maybe still far from. This is so simple if you just come to grips with the fact that every engine is unique. Now if you throw NOS into the mix, how much more different is bike B?
[quote]
f there is no benefit to raising the rev limiter on a Gen1, and I will need to have very different timing and fueling maps than an NA bike, I might as well stick with the old DJ products all by themselves.
Install a Map switch on your handlebar and now you can Run dual maps in your PCV. When your going to spray NOS Flip switch and you're Golden.
I plan to use a map switch between NA and NOS maps as you described. What I am concerned about is the confusion that would arise by comparing my present mapping with tuning refinements that I will do. For example, I can just throw the map I got from the tuner into my PCV, accept trims and it will provide me with a good starting point for tuning. I could do the same with your map. I can also compare your map or maps I create to stock mapping very easily. If I flash, the stock maps are gone from the ECU and are replaced by Romans maps. I'm sure it would be very possible to figure out the stock numbers with some simple math but that would be pretty cumbersome given the number of cells we have on a map. If I ever forget the plusses and minusses to calculate the stock mapping, I would be lost. I guess most people who want a flash want to forget the stock mapping forever but I'd like to be able to refer back to it with as little confusion as possible. It seems less complicated to calculate 12.2 AFR at 5500 rpm in the 30% column is -10.5%. If the mapping is flashed, it might be -5.6% because your mapping of that cell was 4.9% leaner than stock. I would have to have a list of all of this numbers to calculate stock fueling and it would invite the possibility of a lot of errors. Bottom line, if the increased rev limiter isn't going to help me, I see no reason to flash since I will have all the tuning equipment to make the trims I need anyway. A Gen2 with it's increased rev limiter benefits would be a whole different story.
Or buy a second ECU and flip back and forth.
...or I could do that but comparing it to the maps I made from the flashed ECU would still be just as confusing. The ECU is the absolute baseline. Flashed or unflashed, pick your poison.
blah-blah-blah...I think I have my mind made up to not flash right now --perhaps a little ironically, from conversations you and I had about flashing. After the stock mapping is tuned, I don't see why I would decide to flash. I'd be starting the process all over again.
Anything Else inside these ECU's you guys want to see ? No one seems to be flaming me,,, Yet
How about tuning/gear?? Seems two me untamed made a map for neutral and then went straight to tuning 6th gear. So he runs the same mapping for 6th as he does for 1st. Any advantages two making separate maps for each gear? If the process is the same, seems it will be hard to make a map for lower gears where the rpm climbs fast.
* Last updated by: Rook on 2/19/2016 @ 10:02 PM *
