Thread: USB Charging port
Created on: 07/07/25 01:24 AM
Yellawolf504
Yellawolf504's Gravatar
USB Charging port
07/07/25 1:24 AM
Hi everyone
I just wanted to share my usb charging port install with everyone. It was a quick and easy option and cheap as well. I got the charger on Amazon for $17 with two day shipping. It had everything needed for the install, so nothing extra was bought.
Here it is below. I have a galaxy s25 and Google pixel and it does support fast charging and super fast charging. I think i get to 80% in 30 mins so it works great.
https://a.co/d/cU25yTM
I installed it on the handlebar next to the throttle side. It has a pad you put around it before the ring so it gets nice and tight. I ran it hot to the battery so things can charge without having the bike on. It has a switch next to the ports and pretty bright voltmeter on it which is good about reminding to turn it off when done. All I did was take off the right airduct cover and the top side if the right fairing to get to the battery. I ran the wire thru the bracket with the brake lines and went over the duct and behind the fairing right to the battery. Positive to the battery and negative to the body. Use some tie straps to clean it all up. Then put it back together it took about 30 mins very glad I took the time to do it. Hope this helps someone they wants a charger
* Last updated by: Yellawolf504 on 7/9/2025 @ 12:12 AM *
RE: USB Charging port
07/07/25 8:10 PM
Assist:
https://a.co/d/cgYb9hY1
Did you use a fuse on the posi side of the whole loop?
Well, does not loop to the vid. My assist goes blank and if you cut and paste the http, it reverts back to this page.
* Last updated by: Hub on 7/7/2025 @ 8:14 PM *
07/08/25 3:57 PM
Same right cher Hub.
That's one pretty 14R, Yella.
Yellawolf504
RE&amp&#x3b;&#x23&#x3b;x3a&#x3b&#x3b; USB Charging port
07/08/25 11:54 PM
There was an inline fuse in harness of the charger so I just rolled with that one.
Sorry about that, not sure what happened. This one should work. I updated it in the original post as well.
[/url]
* Last updated by: Yellawolf504 on 7/9/2025 @ 12:05 AM *
Yellawolf504
07/09/25 12:00 AM
Thanks I really appreciate it. I love it too. I actually just updated the picture because I put a new exhaust on and I also added a radar detector.
* Last updated by: Yellawolf504 on 7/9/2025 @ 12:11 AM *
