Thread: Dim/Faded LCD display on 2018 ZX-14R
Created on: 05/12/26 07:02 PM
Painkiller
05/12/26 7:02 PM
anyone has dealt with a fading digital display issue. Recently, the LCD on my 2018 ZX-14R has become very dim. It’s reached a point where it’s difficult to read the data during the day and even at night.
It doesn't seem to be a standard brightness setting issue, but rather a loss of contrast or "fading" of the digital readout itself.
Has anyone encountered this on this specific model? I'm trying to figure out if this is a sign of a failing capacitor, a loose ground, or if the screen is simply giving out. If you've managed to fix this without replacing the entire instrument cluster
RE: Dim/Faded LCD display on 2018 ZX-14R
05/12/26 9:02 PM
Sun facing you, no problem. Sun overhead, can't read. Sun behind you, can't read. You can hold down a button and the screen changes to black. Forget the button, maybe the left switch. Just hold down till it changes. Hold down again to revert.
You are the first to mention a fading screen. A lot of years have passed with the same screen. Haven't a clue, sorry.
islandninja
islandninja's Gravatar
Bintan Island, Indonesia
05/13/26 12:32 AM
yes, i sometimes have this problem on my 2013... started happening last year during a highlands road trip, when the ambient temperature dropped down to 13 degC, as opposed to the usual 30 degC we have near sea level where i live... now back home it would happen again, but only every now and then...
when starting the bike in the morning the screen would be totally blank, then as the engine is warming up, the display slowly comes back to life and stays fine for the next few days... at this point it is not a permanent issue, i reckon it could be related to humidity of the air, like after a tropical rain
kind of decided that i can live with it... probably a bad contact or an exposed wire that gets affected by humidity?
interestingly it does not happen after a bike wash
05/13/26 5:24 PM
Wonder if killer lives in a tropical area like you, Island? As I read your post, Issy, I'm thinking low battery voltage. As I read towards the end, the bath said to me: not volts, but a resistance like unplug and re-plugin the connector.
This sort of makes a new drag of bare metal breaking the green resistance of the long in the tooth of metal (copper) living in a damp, aged bike. Happens to dry weather bikes too, but way longer in the tooth by 50yrs.
Race buddy had me work on his single cam 750 Honda. Bike would not start. By guess, there was some lone resistor in the main wire harness. I unplugged it, dipped the connector in vinegar, watched the bubbling stopped and dipped the connector in fresh water. Plugged the resistor back in and the bike lit off.
That's my only guess to this mystery dash dimming - some sort of a resistance factor?
islandninja
05/14/26 2:26 PM
thanks for this Hub... you are probably onto something here too!
i need to pay more attention to the circumstances when this happens, will update when some clues show up...
Stratovarious
Stratovarious's Gravatar
05/26/26 5:01 AM
Sound like a good tip Hub, I'll remember that one.
A funny thing about contacts of a certain type,
I don't remember the ones I was working on
at the moment but I was sanding them trying
to get a better contact, only to learn that
I was making it worse by removing a low resistance
coating. I probably should have used vinegar
or contact cleaner and no sanding/abrasion.
Stratovarious
05/26/26 5:06 AM
Good luck Painkiller, I have no clue, my 2013 doesn't have
screen issues like that, but still, it's useless at certain angles
to sunlight, and shadows.
