I like the Vortex cap but I'm not sure it's real light in weight...although probably lighter than stock.
The stock gas cap is safest if the bike tips over with a full tank. It looks like the stock cap has a cone shaped rubber stopper that seals the filler neck. An aftermarket gas caps may o may not have a gasket on the lid. All have a gasket that seals the seam between the gas cap neck and the fuel tank neck but any gasoline that could make it to the cap would leak past the threads in the lid, if it had no gasket. My bike was on its side for at east fifteen minutes after I crashed but I noticed no gasoline leakage or odor with the LighTech gas cap I have on the bike.
The LighTech gas cap simply vents to the ring shaped recess the cap assembly fits into. Any liquid gasoline would drip into the ring and down the water hole and/or gasoline overflow hole. Some aftermarket gas caps have a rubber tube from the vent in the gas cap. That tube is inserted to one of the drain holes in the ring. I have noticed gasoline drip from a drain tube under the bike when I parked it hot with the tank overfilled. That will also happen with the stock cap. If there are any aftermarket gas caps that aren't vented, I'd be surprised. Even the super cheap Chinese copy of the LighTech gas cap I bought from China had a vent. On the super cheap option, it will probably work fine but chances are they didn't spend the time milling it thoroughly to lighten it up as much as possible. That Chinese cheapy was aluminum but it weighed about the same as stock. The color was off too. I bought it from Ali-Express for about sixty bucks in about 2013.
The LighTech quick release cap I bought in 2012 was $150. It weighs 7.25 oz v the stocker at 14 oz. Aesthetically, it's very pleasing and although the nob on the cap sticks up 3/8" or so, never even knew it was there when I tucked down flat.
The LighTech full spin gas cap isn't as nice looking but it's perfectly flat like the OEM cap. I haven't had the opportunity to weigh it yet but from the info on the ad, I'm guessing it's about 5.5 oz. I don't know if the threads on the full spin cap come loose from vibration. It is conventional threads with no kind of lock. LighTech has a race key to tighten the cap down very firmly but then you have to take that with you on the bike incase you need to fill up. The full spin is more of a race only part if you ask me.
BARGAIN ALERT!
Lightec gas caps are on clearance at OPP Racing right now. I just bought two of them, a quick release in indigo and a full spin cap in black, both $73. I also bought the racing key for the full spin at $38 (LOL half the price of a gas cap). They have a few quick releases for fifty seven bucks, not in my color so I left them for you! No idea why they have quick releases for the ZX-14 under two different products. They look exactly the same but one is $74 and the other is $57. Call OPP and ask if you’re into it. If you order a LighTech in blue, it will be a light sky blue as shown in the photo below. I'd suggest indigo for something closer to a conventional anodized blue color.
You need to set up an account to purchase from OPP. It’s like becoming a member of an exclusive club! I’ve bought from them three times back in 2012. No PayPal but they’re legit. You can trust them. I find the website a bit hard to navigate and the payment process is a little ambiguous but it's always worked for me with no errors in billing.
The greatest gas cap is made by Accossato, 4.58 oz. There is a five bolt that fits the 06-20 ZX-10. Looks like you could put a couple bolts in the two extra holes with a nut underneath if the other three matched up to the position and depth of the boltholes in the tank ring. Then you’d have to be concerned about the depth and position of the neck of the gas cap matching up with that of the neck of the fuel tank. I wouldn’t want to mess with that. Might look into it in the future.
The Driven Halo gas cap is my favorite for looks. The black with blue cap would go real nice on my 2024. It claims a 30% weight reduction so it’s probably only about a 4 oz less than stock.
One thing I’ll miss is the quiet whine this Gen2 makes after it’s parked hot. My Gen1 was kind of loud and weird like a tea kettle but I kind of like the soft noise this one makes. …however, I can’t live with a gas cap that wont lock or unlock. Yeah, kind of strange that Kaw didn’t address that on the Gen2.
So that's about everything I know about aftermarket gas caps. Here's my LighTech on the Gen1.
* Last updated by: Rook on 9/5/2025 @ 7:59 PM *
08 MIDNIGHT SAPPHIRE BLUE ZX-14 Now Deceased, will be resurrected, 08 Hayabusa,
2024 ZX-14R bran friggin NEW and 2026 hayabusa!
