Here is how you trip this guy up:
When an engine is not running, we can say the 'back pressure' is there and should be breaking the bike's cases of every engine know to man. If back pressure is 14.7psi we have the bike sitting dead engine in the garage my case is in jeopardy! If we then fire up the bike, is not a pressure trying to get back in [14.7] to fill that void once the valve is closed/open?
Out of 4 cylinders, one is without a spark and waiting. At the same time, another cylinder has a valve open. At some time, it means there is no pressure from the engine out of the exhaust. It is now reversed to back pressure; back into the pipe as fast as lightening.
Therefore, every engine should break and bust through a case that is caused by back pressure.
WOT a fucking world you put that guy in charge of some sort of diagnose for a factory rep.
__________________________________________________________________________________________
Piston Damage:
1. We need to see a burned skirt caused by heat. If the skirt is clean, no heat to that piston.
2. We need to see if there is a hole at the top of the piston dome. If there is, we can blame the PC if we need to blame a variable. Then we have to have the other 3 pistons all det and hot to score a skirt is the heat transfer of some hot hot heat that took out #4 piston.
3. We need to see very little damage from the dome right where the deep reach plug meets at TDC. If all 4 look the same, we can see det would take out one cylinder at that area and keep going, taking out the other 3. If it is clean, we need to look somewhere else besides a damaged piston. Now if piston is damaged from the crank rod stretched in half, we have an x-ray flaw is the human eye may have fell asleep that one time are the odds to that?
That engine has to be so carefully torn down to determine if it is rider abuse or just that engine numbered so close to the other rods letting go through the case. And who better has that warranty record? It is rather a factory flaw we have connecting rod parts split in half. It is not an oil problem IMO, or we would have one case hole after the other without any blemished parts, meaning, count out an oil design problem is my guess.
* Last updated by: Hub on 7/27/2010 @ 10:41 AM *
